588,551 active members*
5,722 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Wall thickness using Aluminium
Results 1 to 5 of 5
Threaded View
    Sep 2016
    5
    Hi all
    I haven't CNC'd in metal before, and could do with some advice.
    I've attached a sketch - how thin could I make these walls if using aluminium? The design as it stands has 6mm walls. Could that be brought down to something like 3mm, and still be rigid enough to withstand CNCing?
    Thanks!
  1. how to add a wall thickness
    By yllis in forum Rhino 3D
    Last Post: 02-14-2012, 08:53 AM
  2. Machined aluminum cylinder. Wall thickness for HPA?
    By D.C. in forum Mechanical Calculations/Engineering Design
    Last Post: 04-07-2011, 12:14 AM
  3. MIC6 Aluminium thickness
    By welshtom in forum MetalWork Discussion
    Last Post: 12-19-2010, 01:25 AM
  4. Wall thickness for threaded tubing
    By Rockwall in forum Mechanical Calculations/Engineering Design
    Last Post: 07-19-2009, 07:09 PM
  5. Steel rectangular/square tubing wall thickness
    By pstockley in forum MetalWork Discussion
    Last Post: 01-27-2006, 08:56 PM
