Hello everyone,
Short question is, is there any software that let you choose or modify the toolpath before converting it to g-code from a dxf or dwg file?
Context:
When we convert the dxf to g-code, the toolpath that the convertion choose is the order the design was drawn, so if you draw the outer lines first, and then the inside ones, there are high chances of getting a fail piece. When you only have a small desing that is no problema, but we are cutting 2x3 meters steel sheets with more than 100 cuts, more less 3 hours of cutting.
So is pretty difficult to not mess up the toolpath. So, someone know if there is any software to modify that toolpath before or after the g-code is done?
Thank you for your help
