603,330 active members*
3,104 visitors online*
Results 1 to 5 of 5
Threaded View
    Feb 2017
    11
    Z AXIS MOVES RANDOMLY (UPDATE)
    Hi guys, hope you can help me, i got a cnc router form china, is the common heavy duty 1325, the machine was working fine in the past, is a machine the only use sometime and his main funtion is to surface cleaning wood slabs for dinning tables and coffe tables, but in this week is making an issue, it randomly plunge the z axis down, it star moving the z axis down little by little, ruining jobs and the slabs, the issue also happen when the job is finish and the machine goes to zero and the spindle stop, when the spindle is stopping th z axis moves, ill atthaced the link of the video of the issue and the photo of the machine.
    Also ill atthached the g code of the surface clenaing job.
    I change the pc hopping that resolve the problem but it doesnt, the issue is still there, im not expert and i cant see if the problkem is mechanical, config or something elsehope somebody help me with this issue and thanks for your time guys.
    link video:
    https://youtube.com/shorts/KL-B00Bh3lI?feature=share
    UPDATE:
    for some reason im cant modify my previous post, but this is an update of my original post, i make some cutting test in my cnc in order to ule opuyt if the issue persist even in cutting works, i cut 3 sheets of plywoods, ill atthaced the dxf file and the g code, was like 20 min for each one of the sheets of plywood and my machine work perfectly, no issues and all good, im still dont know if only with pocket toolpath file the issue can occur, ill make a teso of a new pocket toolpath tomorrow and ill let you know, but in this post ill attahced the vcarve file and thew gc ode of the pocket toolpasth work that i use when my machine make the issue of z axis plunge randomwly, in the new pocket tollpath file ill makqe for making the test ill use the mach2/3 atcv (mm) .txt post processort and see if the issue occur or not, im using mach2/3 arc (mm) .txt in dont know if i use atc will be a problem is the workm only use 1 tool, hgope anyuone can help me with this.
    For the peolpe that repsond in my previous post i say thank you for taking the time.
    Note:
    I use aspire for de desing and mach3 for control de cnc
    Attached Files Attached Files
  1. Z AXIS MOVES RANDOMLY
    By gporthos in forum Mexican Club House
    Last Post: 05-08-2022, 12:13 AM
  2. Axis randomly stop working
    By groc426 in forum Mach Software (ArtSoft software)
    Last Post: 01-07-2018, 04:58 PM
  3. Y axis moves randomly in a direction
    By HansD in forum DIY CNC Router Table Machines
    Last Post: 07-30-2014, 11:43 AM
  4. X-axis randomly scales to -1
    By sharbin in forum Mach Mill
    Last Post: 03-04-2011, 03:05 AM
  5. Z axis randomly plunging
    By Don-in-Japan in forum Benchtop Machines
    Last Post: 05-31-2009, 07:58 PM
