603,374 active members*
2,982 visitors online*
Results 1 to 5 of 5
    Mar 2011
    X-axis randomly scales to -1
    I have tried running several g-code examples in Mach 3. The first time after running Mach 3 and loading the code, it seems to run just fine. After rewinding and restarting the same code cycle, sometimes the x-axis will inexplicably change the scaling to -1 (scale "LED" flashes and displays -1. A few of the initial cuts may start out ok but then it suddenly reverses and all subsequent cuts are mirror imaged wrt the x-axis. Rewinding and trying again gives the same behavior. Manually resetting to +1 doesn't seem to cure it.
    Any ideas on what I am doing wrong?
    Mar 2003
    35494
    Do you have a legitimate license?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2010
    haha thats funny I had the same problem. I was running mach3 w/ a pirated license. Get a legit license and it should fix it
    Mar 2011
    How do I determine if my license is legit?
    Mar 2010
    Is your name on the top bar next mach3 cnc?
    Also you have to purchase the license
  1. Z axis randomly traveled .150 for no reason
    By Gun-Machine in forum Tormach Personal CNC Mill
    Last Post: 01-11-2011, 11:38 AM
  2. DRO - Glass scales or cheap Chinese digital scales?
    By strandbygaard in forum Benchtop Machines
    Last Post: 04-05-2010, 03:01 AM
  3. Where to buy 3 axis DRO glass scales
    By fnm in forum Want To Buy...Need help!
    Last Post: 09-16-2009, 01:58 PM
  4. Z axis randomly plunging
    By Don-in-Japan in forum Benchtop Machines
    Last Post: 05-31-2009, 07:58 PM
  5. Two Scales for Z- Axis?
    By TZ250 in forum Milltronics
    Last Post: 09-11-2006, 03:56 AM
