587,518 active members*
3,210 visitors online*
Results 1 to 5 of 5
Threaded View
    Jun 2005
    142
    Indexer software
    For those running an indexer here is a email of Rich, [email protected], who has written 2 wizards so far for the indexer. I have been working with both and they are great. Rich is a retired programer who has been building CNC machine running Mach since Mach's early years. He also helped a friend upgrade his Legacy Ornimental mill to CNC. The perfect background for doing indexer wizards.
    One wizard is to do spiral cuts. Designed mainly to do rope/barley twists. It allows to use A, B or C as rotational axis, do CW or CCW twists, select depth of cut, etc. Here is a 14" piece I did.
    The other wizard will wrap a file around a cylinder using A, B or C as the rotational wizard. Both work great and he is going to write more.
    The other option is http://legacywoodworking.com. They have released the beta version of a spread sheet that will do rounding, fluting and rope/barley twists. Price is $100. Right now it's only advantage over Rich's wizards is that it will do fluting. Hopefull Rich will fix that shortly.
  1. SMW Indexer program. HELP!!!!
    By protec in forum MetalWork Discussion
    Last Post: 08-21-2019, 01:15 AM
  2. Haas VF1 & 5C Indexer
    By lovell110 in forum Haas Mills
    Last Post: 12-08-2007, 06:39 AM
  3. Nickolis indexer
    By Kevin Taylor in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-10-2006, 04:07 AM
  4. indexer question
    By pit202 in forum Haas Mills
    Last Post: 11-30-2006, 05:45 PM
  5. Indexer LPT - HELP!
    By CNC Pro in forum Uncategorised CAM Discussion
    Last Post: 03-11-2004, 09:20 PM
