603,780 active members*
2,867 visitors online*
Results 1 to 4 of 4
    Nov 2005
    43
    Haas VF1 & 5C Indexer
    Hi All,
    I have a 1991 VF1 with a vintage 5C indexer with its stand alone control. I was hoping to use the indexer with out the stand alone control. I know that both of these have brushes in them and I do have the 4th axis capability. My dilema starts with the plugs. My machine has a 17 pin plug while the 5C male plug is a 7 pin plug. Is there a way to make the 5C unit compatable with my VF1? I am not an electronics expert so all of you super geniuses keep in dumb dumb language for me. Thanks in advance for your help.
    Mar 2003
    928
    I don't think that is possible..as the 7 pin indexers where stepper motors, not servos..
    You can run a 14 pin indexer on a 17 pin machine with a adapter from Haas..but never seen or heard of a 7 pin to 17 pin..or 7 pin to 14 pin one..
    Nov 2005
    43
    Would it be possible to switch out the motor? I would like to be optomistic that the frame work for the indexer has not changed much.
    Mar 2003
    928
    Sorry no idea..might call Haas and ask them..
    Some of the older stepper ones where quite different than than the servo ones..
  1. Haas Indexer
    By binzer in forum Haas Mills
    Last Post: 12-16-2009, 03:10 AM
  2. Haas Indexer Alarm
    Last Post: 07-10-2007, 09:11 PM
  3. Haas Indexer hrt610
    Last Post: 06-07-2007, 04:30 PM
  4. Haas S5C Indexer motor
    By Andrew M. in forum Haas Mills
    Last Post: 09-02-2006, 03:57 PM
  5. Haas indexer servo motor help.
    By Andrew M. in forum Servo Motors / Drives
    Last Post: 01-22-2006, 01:26 AM
