603,963 active members*
3,212 visitors online*
Results 1 to 15 of 15
Threaded View
spalm Wooden Gears? 05-05-2005, 12:47 AM
ger21 You set the depth in Visual... 05-05-2005, 02:56 AM
ynneb What is this "3DGEARS.lsp"... 05-05-2005, 04:28 AM
spalm I'm tring to post a sample... 05-05-2005, 04:48 AM
ger21 Benny, AutoCAD usesa... 05-06-2005, 12:46 AM
azam1959 Reusable Inventor component... 08-23-2012, 01:31 PM
DareBee For working with AutoCad and... 05-05-2005, 01:44 PM
spalm Follow up 05-05-2005, 03:10 PM
CNCRob Hey Spalm, The gears you... 05-15-2005, 11:01 PM
spalm The gears were cut with a... 05-16-2005, 01:48 PM
nine6 update on wooden gear cutting 03-02-2007, 04:37 AM
Ken_Shea nine6, Alibre Design Express... 03-02-2007, 05:03 AM
    Feb 2005
    578
    Wooden Gears?
    Well, I got my first CNC going. Now to figure out something to route with it. First thing that came to mind was my second router, but the wifey thinks I should slow down and do something else with it first. So a wooden clock was discussed. It will also hone my Autocad skills which are non-existant[IMG]. Found some plans on the web, extracted a few dxf files and routed them. I had to manually set the Z axis in the gcode files as VisualMill saw it as only a 2D object. They were a real crowd pleaser. Also gives the XY table a good work out.
    Now I want to design my own and am a complete newbie with Autocad. How do you draw a gear? I found a little application called 3DGEARS.lsp that I loaded into Autocad and it lets me draw them but then I don’t know how to save them so VM will see them. I think I have a major mental problem with 2D or 3D. How do I draw a hole down the center? Should I save it in DXF or DWG and what is the difference? Do I do this with layers, or is it something else. Should I export it to IGS?
    Thanks in advance,
    Steve
  1. making wooden props
    By Paraprop in forum DIY CNC Router Table Machines
    Last Post: 04-14-2009, 01:28 AM
  2. Internal Gears???
    By itsme in forum MetalWork Discussion
    Last Post: 02-11-2005, 09:21 PM
  3. RFQ Mod1 Gears
    By SonicBlast in forum Employment Opportunity
    Last Post: 01-15-2005, 07:50 PM
  4. custom gears
    By studysession in forum MetalWork Discussion
    Last Post: 12-01-2004, 12:36 PM
