587,259 active members*
3,035 visitors online*
Results 1 to 7 of 7
Threaded View
    Mar 2011
    RFQ: Flat Wood parts: 1/2" and 1/8"
    woodrfq
    Hello,
    I am looking to get an estimate for these wood parts (see attached PDF.)
    Please quote the following:
    • Some parts are either hard ply or solid 1/2" wood stock (something harder than pine if solid stock)
    • Some parts are 1/8" birch ply (a nice smooth finish-quality ply)
    Quantity:
    Please estimate 10, 50, 100, and 500 count. (The contents of the PDF = 1 count.)
    Timeframe:
    There is no hard timeframe, this is a personal project of mine.
    Materials:
    I would like you to include a material estimate as a line item.
    Production Method:
    I don't know if 1/2" wood can be laser cut, or this is a routing job, or whatever. It doesn't matter to me as long as the final results are clean and accurate to 1/32"
    Midwest preferred. I am located in Indiana.
    Files:
    The PDF file is attached. The password required to open the attached PDF is the first word of this post. I can provide the final files in any common vector format.
    Contact:
    Please email me at the address within the PDF document if the PM space on this forum is limited.
    Attached Files Attached Files
  1. LouieAtienza's "Dovetails on the Flat" Technique, take 1
    By louieatienza in forum WoodWorking Topics
    Last Post: 07-27-2020, 08:16 PM
  2. .170" Dia 1" Deep Flat Bottom comes out tapered
    By nfrees114 in forum MetalWork Discussion
    Last Post: 12-08-2010, 10:50 PM
  3. keep a 13" x 13" x 3/16" plate flat?
    By bigalexe in forum MetalWork Discussion
    Last Post: 05-01-2009, 06:58 PM
  4. Making brackets; bending 1/4" x 3" aluminum flat stock
    By guru_florida in forum Bending, Forging, Extrusion...
    Last Post: 06-08-2008, 11:48 PM
  5. How do I fix 4"x1/4" flat to 3"x3"x1/8 box without welding?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 10-18-2005, 02:18 PM
