587,722 active members*
3,495 visitors online*
Results 1 to 7 of 7
    Mar 2011
    RFQ: Flat Wood parts: 1/2" and 1/8"
    woodrfq
    Hello,
    I am looking to get an estimate for these wood parts (see attached PDF.)
    Please quote the following:
    • Some parts are either hard ply or solid 1/2" wood stock (something harder than pine if solid stock)
    • Some parts are 1/8" birch ply (a nice smooth finish-quality ply)
    Quantity:
    Please estimate 10, 50, 100, and 500 count. (The contents of the PDF = 1 count.)
    Timeframe:
    There is no hard timeframe, this is a personal project of mine.
    Materials:
    I would like you to include a material estimate as a line item.
    Production Method:
    I don't know if 1/2" wood can be laser cut, or this is a routing job, or whatever. It doesn't matter to me as long as the final results are clean and accurate to 1/32"
    Midwest preferred. I am located in Indiana.
    Files:
    The PDF file is attached. The password required to open the attached PDF is the first word of this post. I can provide the final files in any common vector format.
    Contact:
    Please email me at the address within the PDF document if the PM space on this forum is limited.
    Attached Files Attached Files
    Feb 2006
    196
    Your PDF document is password protected.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    [email protected]
    Mar 2011
    Quote Originally Posted by dpryor View Post
    I have found it to be a good way of weeding out those would-be vendors who can't even be bothered to take the time to read the first post.
    Works every time.
    Apr 2011
    132
    Quote Originally Posted by nventian View Post
    woodrfq
    Hello,
    Quantity:
    Timeframe:
    Materials:
    Production Method:
    Files:
    Contact:
    Your drawings does not have any dimensions.
    Mar 2011
    Quote Originally Posted by WATERJET71 View Post
    Parts are actual size in the PDF. Longest part is approx 7"
    Apr 2011
    132
    Good luck , nobody its going to give you a quote without dimensions if you give a dxf file that's a different story. That approximate doesnt fit when you are machining, that's only me I never give any prices if I dont have any dimensions.
    Mar 2011
    Thank you. Dimensions have been added to the PDF and the PDF file has been updated.
    Edit: ALL dimensions have been added.
  1. LouieAtienza's "Dovetails on the Flat" Technique, take 1
    By louieatienza in forum WoodWorking Topics
    Last Post: 07-27-2020, 08:16 PM
  2. .170" Dia 1" Deep Flat Bottom comes out tapered
    By nfrees114 in forum MetalWork Discussion
    Last Post: 12-08-2010, 10:50 PM
  3. keep a 13" x 13" x 3/16" plate flat?
    By bigalexe in forum MetalWork Discussion
    Last Post: 05-01-2009, 06:58 PM
  4. Making brackets; bending 1/4" x 3" aluminum flat stock
    By guru_florida in forum Bending, Forging, Extrusion...
    Last Post: 06-08-2008, 11:48 PM
  5. How do I fix 4"x1/4" flat to 3"x3"x1/8 box without welding?
    By Apples in forum Mechanical Calculations/Engineering Design
    Last Post: 10-18-2005, 02:18 PM
