587,202 active members*
2,995 visitors online*
Page 6 of 7 4567
Results 101 to 120 of 123
  1. #101
    May 2008
    142
    Hi Rory
    Yes guides are top and bottom, you should be able to see in this thread on the pictures.
    Cheers. Michael
  2. #102
    May 2008
    142
    Zero Touch Plate
    Hi guys
    Went shopping at bunnings and found the perfect zero touch plate for $13.
    Will call into jaycar tomorrow and pick up some curly cable.
    Pictures to follow for this mod.
    Stay tuned !
    Michael
  3. #103
    May 2008
    142
    cnc touch plate
    Here is the mod for touch plate and video testing.
    I also glued a piece of PVC to insulate the bottom as its all metal.
    The top plate is spring loaded so if your z axis doesn't stop you got split seconds to hit e/stop.
    [ame=http://www.youtube.com/watch?v=BJnjKVW57jk&feature=player_detailpage]cnc touch plate - YouTube[/ame]
    enjoy Michael
    Attached Thumbnails Attached Thumbnails cnc touch plate 001.jpg   cnc touch plate 002.jpg   cnc touch plate 003.jpg   cnc touch plate 004.jpg
    cnc touch plate 005.jpg   cnc touch plate 006.jpg   cnc touch plate 007.jpg   cnc touch plate 008.jpg
  4. #104
    Nov 2011
    I've seen these before but don't quite understand how they work. I know its to do with aligning your tool bit to the material to be cut or something along those lines?
  5. #105
    May 2008
    142
    Its to set the zero height of the material the easy way.
    When you hit the zero probe button on you Mach screen the spindle comes down slowly and when it just touches the plate, it will offset the thickness of the plate and set the zero for the material height.
    Hope that helps. Michael
  6. #106
    Nov 2011
    Quote Originally Posted by mkc2 View Post
    So the plate isn't fixed on the machine it is movable to sit on whatever material you are going to cut?
  7. #107
    May 2008
    142
    Yes that is correct.
    This way you don't have to try and see when the mill end is touching the material or if you go down to hard you can mark the surface, if it's nice shiny aluminum.
  8. #108
    Nov 2011
    Ahhh I see! All is clear now. Thanks for your help! I've got to get my machine running first before I start thinking about improvements! I'm sure what you've showed here will help a lot when it comes time! Thanks for your help.
  9. #109
    May 2008
    142
    MorloU8
    Not sure what you mean, but the thread is about everything I've done with this cnc router.
    Regards Michael
  10. #110
    May 2008
    142
    Glad I could help, I wasn't out to make this touch plate, I just saw it on the shelf and my mind started racing around until the light bulb popped up on my head.
    I love it! 10 minute job all done, now I will get another one for a permanent tool change offset height.
    Enjoy Michael
  11. #111
    Sep 2010
    60
    Hey mate.
    Congratulations for your idea! (your touch plate is awesome!)
  12. #112
    Feb 2012
    Hey mate.
    How do you know he's still around?
  13. #113
    May 2008
    142
    Still around, just got so many other hobbies.
    Rc tricopter, quad copter and now stormtrooper armor build.
    Cheers Michael
  14. #114
    Nov 2011
    Do you remember what your touch plate button was actually supposed to be so I know what to look for at Bunnings or elsewhere? And also how did you set it up with Mach3? I understand there is some coding that has to be changed or entered?
    Thanks!
    Rory
  15. #115
    May 2008
    142
    It's the base for a door stopper at bunnings, I'm using a Mach3 screen set that i bought for the touch plate and tool change.
  16. #116
    May 2008
    142
    Hi all
    I'm still floating around in the background, been busy with all my hobbies.
    Been helping my brother lately with his HM46 cnc milling machine.
  17. #117
    May 2008
    142
    Picked up a 3D printer, a lot cleaner making bits then the CNC machine!!
  18. #118
    Nov 2012
    43
    That is one nice machine you've built there!
    great work mate!
  19. #119
    May 2008
    142
    Quote Originally Posted by baskarz View Post
    great work mate!
    Thanks Baskarz
  20. #120
    May 2008
    142
    Well I have been busy building other things and the latest is a Vacuum Forming Machine.
Page 6 of 7 4567
  1. Steel frame Ganrty router build
    By matth in forum CNC Wood Router Project Log
    Last Post: 10-30-2014, 08:32 PM
  2. Steel Router build 1500x1000
    By Bl@ckrat in forum DIY CNC Router Table Machines
    Last Post: 02-28-2014, 07:14 AM
  3. Steel 1.2m*1m Router build
    By Jtepper in forum DIY CNC Router Table Machines
    Last Post: 01-18-2013, 08:20 AM
  4. New 4x8 Steel CNC router build
    By Ernie34 in forum DIY CNC Router Table Machines
    Last Post: 11-25-2012, 01:41 PM
  5. First Router Build - 4x4, steel, R&P
    By cxixer in forum CNC Wood Router Project Log
    Last Post: 02-09-2008, 09:15 PM
