587,524 active members*
3,360 visitors online*
Page 18 of 22 81617181920
Results 341 to 360 of 434
  1. #341
    Oct 2008
    1641
    Yes, I did that on my SX3 in order to keep the Spring washers lined up. It helped a lot on vibration and finish. I call it a top hat !!
    Richard
    Quote Originally Posted by pete from TN View Post
    I am planning to actually make the spring stack housed in it's own casing that will keep them clean and it will all act against the top of the spindle and it will only surround the spindle with a small flange to keep it aligned.
    Pete
  2. #342
    Apr 2007
    2580
    Funny again....
    That is what I call it as well...haha peace
    Pete
  3. #343
    Aug 2008
    962
    Yep .. after suggesting it I also did some searching & realized there's WAY more to it than number of threads & type of material.
    On my machine it is just the splines that are threaded but I've got a good 1"+ of threaded contact with the pull flange & plan on starting at 2200# pressure.
    I'm with you on this thing .. if it don't work .. figure out something that will!
  4. #344
    Jan 2011
    385
    You could turn down the splines at the top for say 2-3" to it's root diameter. Now you can make your PDB nut to go inside the pulley as well as hold it on with a shoulder. On the top of the nut would be where you make your groove for your PDB to put force on. I would make it fairly large so as to cover up the spring stack and also locate the springs on center. Since you are not using your quill you don't need the top splines on the spindle. This is how I was planning on accomplishing the PDB topper for the spindle.
    If you have the spring stack act on this "top hat" then you might not even need to thread it on at all. 2000 lbs of force might just be enough to kept everything together. Then you wouldn't have to worry about getting it off the spindle when it comes time to take it apart.
    Jeremiah
    PM45 CNC Build in Progress
  5. #345
    Oct 2008
    1641
    Grease
    Where did you all buy your Kluber Grease at?
    Richard
  6. #346
    Search the Kluber Shop Online
    for the Isoflex NBU-15, you need
    to create an account to see the pricing and order.
    A 50 gram tube will go a long way.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  7. #347
    Nov 2006
    40
    Could you use a thick spacer for your drawbar/quill spacer to gain the disc spring clearance?
  8. #348
    Oct 2008
    1641
    Thaks Hoss, I ordered some. I thought it was available from other sources as well and just wanted the best price.
    Endo, I guess I could but I wanted the spindle threaded so I'm dislodging my collet at the same time. I ended up trimming here and there and got a good 3/4" of threads and also opened up my spindle drive ID some so I could get another 3/4" or so down inside. The internal portion will only have a 0.150 wall but the section above the pulley will have lots of beef. Hopefully Maglin's idea will get me that additional thread.
    I'll shoot a couple pics later. I just got finished turning and threading the spindle. I'm polishing bearing fits right now.
    SKF bearings everywhere on this mill and then they used KBC bearings in the spindle. I've heard of them before but I don't know if they are any good or not.
    Richard
  9. #349
    Oct 2008
    1641
    Got some SKF Bearings ordered. The KBC are made by FAG Bearing but they only had like a 5100 RPM rating. The SKF are a couple thousand RPM higher.
    Here are the threads on the end of the spindle, 7/8"-20. Looking at it, 0.760" above the pulley and another 0.750" in the pulley. There is just enough room for a thin wall nut.
    Attached Thumbnails Attached Thumbnails DSC02515.JPG   DSC02516.JPG   DSC02517.JPG   DSC02518.JPG
  10. #350
    Nov 2006
    40
    Richard, VERY NICE!. Looks like you have a great plan. Thanks for sharing and looking forward to watching your progress.
    Ron
  11. #351
    Oct 2008
    1641
    What is a good material to make a new draw bar out of? I have to extend mine now.
    Both pulleys are broached and the keyway milled. I made a custom key 0.375" wide by 0.275" tall due to the lack of wall thickness in the pulley and spindle adapter.
    It's all pressed together and I test ran the motor at 5400 RPM all the way down to 50 RPM and smooth as silk.
    There appears to be a tad bit of run out on the spindle pulley. I didn't measure it yet. I machined it all without removing it, except for facing the other side so maybe that is what I'm seeing.
    I won't be back until Saturday. I have a long 17 hour job in Dallas tomorrow and then TG at my sisters. When I get back, it's time to start milling the mill's top cover nice and flat and put some ledges on it, then make some brackets.
    Sure wish I could make all this on the RF45 instead of the SX3. It would go so much faster!!
    Still to do:
    A) Draw the brackets up in CAD.
    B) Mill both sides of the top cover flat and then mill a ledge 0.125 deep down the sides for the brackets to sit on.
    C) Mill the 1/2" plate side brackets. Both the motor mount and PDB will sit on these two brackets.
    D) Make a Top Hat for my washers and PDB.
    E) Make a longer drawbar.
    Pictures in a few days.
    Richard
  12. #352
    Oct 2008
    1641
    Thanks. Those threads actually look good and feel good in person. The picture make it look a little ratty. I think it's because at 0.875" O.D. the splines did not totally clean up. There was maybe 0.005-0.010" of the splines left.
    Richard
    Quote Originally Posted by endo47 View Post
    Ron
  13. #353
    Aug 2008
    962
    Richard,
    I bought a length of 7/16-20 hardened all thread & a couple grade 8 nuts .. Wound up only using one nut because I made a second one to match the taper on the inside of the piece I put on the cylinder ..
  14. #354
    Mar 2009
    1114
    I've made drawbars from stainless, and they hold up really well. Preferably 304. You could probably get away with 303 though.
  15. #355
    Jan 2011
    385
    Wouldn't some 1045 heat treated work out just fine for a drawbar? Really only need to heat treat the threads and the head where the cylinder is going to be acting on it. Then the center won't be so brittle/hard and have a little spring to it so it doesn't snap. It is what I was planning to make mine out of once the PDB is ready to go on.
    Richard your nut job looks great to me. It's amazing how the camera really can make a good looking job not look so good. I think it looks great. How you went about it is how I pretty much envisioned it. Kept the updates coming. I need more time to work on mine.
    Jeremiah
  16. #356
    Oct 2008
    1641
    Belt drive going....
    Okay, a little bulky looking but It allows me to get my fat fingers in there. A tad over 7000 RPM at 130 hz.
    I have to start on the PDB parts next. My Fabco cylinder is a 3 stage, 4" with quick return (Another Single acting cylinder for return) and it's a Top Mount so I have to machine new end plates for it.
    I thought about removing the piston from the quick return and adding a spring so I don't have to have 2 way air.
  17. #357
    Aug 2009
    899
    HAHA nice I like it... It reminds me of the Roman Aqueducts.
  18. #358
    Oct 2008
    1641
    Yep. looks a little Roman to me as well.
    You know, that threaded flange that goes on the spindle doesn't see the full 2500# or whatever on it, It only see's the pressure it takes to pop the collet loose from it's taper.
    If it was not screwed on the the spindle at all, like Pete said, the sissor action would depress the springs, then the weight of the cylinder would have to unseat the collet.
    So you can see this whole ordeal on how many threads and what type of material was way overkill.
    Richard
  19. #359
    Aug 2008
    962
    Yea, but that's half the fun in these projects .. Figuring that stuff out!
    Looking good Richard .
  20. #360
    Aug 2008
    962
    Richard,
    Just re-read your last post about the scissor action depressing the springs and it got me to thinking .. that would depend upon the springs resting on top of the flange wouldn't it?
    In my case they don't. The Belleville washers sit directly on top of the spindle so there would be no scissor action without the flange being threaded to the spindle.
  1. RF45 XY Squareness
    By wfung in forum Benchtop Machines
    Last Post: 02-03-2010, 05:38 PM
  2. My New CNC RF45...
    By GMitchell in forum Australia, New Zealand Club House
    Last Post: 09-08-2009, 05:02 AM
  3. RF45 Oil Capacity
    By ranchak in forum Charter Oak Automation Support Forum
    Last Post: 06-06-2009, 07:04 AM
  4. RF45 CNC , turn key
    By cncuser1 in forum Benchtop Machines
    Last Post: 05-12-2009, 12:39 PM
  5. At China buy RF45 only USD 812
    By szcharle in forum Knee Vertical Mills
    Last Post: 11-18-2006, 01:09 AM
