587,834 active members*
3,187 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Meldas 520 AMR, RS 232 Signal ground wire gets hot
Results 1 to 19 of 19
    Jun 2008
    230
    Hi all Meldas friends!
    I recently bought another Feeler FV-800A with 4:th axis and Meldas 520AMR control. The annoying thing is that the RS 232 does not seem to work on this one. The setup and configuration is an exact copy-over from my other Feeler. I even use the same PC, same serial cable and the parameters are set exactly as on the other working Feeler. But on this one I get no data transmission and a hot signal ground wire. I believe it indicates a ground potential which is odd, as I power the PC exactly as I do with the other machine.
    Can it be something inside the control's communication card QX522?
    How do I check that the RS232 port on that card works?
    Meldas 520 AMR control.
    My RS232 cable set up for hardware handshake.
    Oct 2005
    672
    Certainly could be a grounding issue. Specifically, it sounds like something on the CNC is not properly grounded and is connecting to ground through the PC.
    If you have a multimeter, leave the RS-232 cable connected at only one end (either PC or CNC) and leave the other end disconnected. At the disconnected end, check for any voltage between the metal housing of the serial connector and the PC/CNC. Ideally, there should be no voltage. Check for both DC and AC voltage. I have seen machines in the field with as much as 30VAC between the machine and the PC.
    Jun 2008
    230
    Thanks Caprirs,
    I take it that you mean measuring voltage between the D-sub connectors metal frame and the PC's or CNC's frame ground?
    I will check the "new" CNC first as it is when my PC + cable gets there the trouble begins.
    Oct 2005
    672
    Yes, the metal frame/hood/shell. Hopefully, there is some voltage there so some simple grounding will solve the problem. Much cheaper than sending the board into Mitsubishi!
    Jun 2008
    230
    I sure hope it's not the board.
    One interesting thing, I found out yesterday, talking to the previous owner:
    When he connected his laptop, trying to output the parameters etc., he encountered the same problem = the signal ground wire got hot and there was no transmission. But as soon as he removed the laptop's charger that was attached to an AC line, it worked.
    Jul 2009
    219
    I have a couple older Leadwells with Meldas MO controls, I have had trouble communicating with one using a laptop while the other Identical machine using the same cable, same laptop works fine. The only difference was where I plugged the laptop into the wall. I have been meaning to install a transformer in the machine to power the laptop from. This way, the laptop ground and the machine ground will be connected and hopefully get rid of any ground issues.
    On another note, I am interested in adding a 4th to My machine with the Meldas 520, Could you tell me how the 4th is set-up on yours? Is it a 4th drive in the control or a stand-alone like a Haas etc..? Is it an indexer or a simultaneous 4th?
    Jun 2008
    230
    A1CNC,
    So the laptop worked with both machines when not plugged into the wall? Then, when you plugged it into the wall, one of the machines got hot wire due to ground issue? Which wire got hot and did it transmit or not?
    I tried to power my PC from the cabinet's 220V line (after the large main transformer) and the ground from the ground plate inside the cabinet.
    Same result, hot signal ground wire and no transmission.
    I suspect that there is something wrong inside the QX 522 CRTC Board.
    What exactly is "signal ground"? Plain Frame Ground -or what?
    How can I check my RS232 port? Check that it transmits and receives signal etc.
    Jun 2008
    230
    A1CNC,
    Re. your 4:th axis plans:
    Meldas 520 AM is already prepared for a 4:th axis = "B" axis.
    You need to get a servo amplifier (drive) MDS-A-SVJ-06 or MDS-B-SVJ2-06 and a 4:th axis rotating table with a Mitsubishi servo motor (HA40NC-S complete with encoder) on it. I think you can use the larger MDS-A-SVJ-10 or MDS-B-SVJ2-10 drives as well, but I am not sure (it has to be checked).
    You also need a signal bus cable between the drives, + encoder cable and power cable to the servo motor. Then you enable 4:th axis in the parameters and load all parameters for the drive.
    The servo drive for 4:th axis is the one to the far right. As you can see, it is smaller than the others.
    The 4:th axis should have one of these. The larger X-, Y- and Z-type ones do normally not fit on a rotating table.
    Jul 2009
    219
    Thanks for the info on the 4th.
    As far as communicating,
    I could send/ receive at slower speeds,(2400 baud) which is pretty useless to either machine and (1) machine I could reliably drip-feed. I never noticed a hot wire at all but I never checked either.
    When I 1st tried the same settings on the 520 I couldn't communicate, I finaly found settings that work but they are different than my other machines with the Meldas MO controls. I will compare my cable tomorrow to yours, and get the settings that work for mine.
    Do you have the manuals for your 520?
    Jun 2008
    230
    Follow this thread to get Mitsubishi Manuals:
    http://www.cnczone.com/forums/mazak_...ml#post1054135
    Jun 2008
    230
    As the setup of the new machine is more or less similar to my other working Feeler, I bit the bullet and bought an RS 232 Optical Isolator:
    http://www.exsys.ch/download/catalog/ex_47925.pdf
    I will install it durning the nearest days an report the outcome.
    On my earlier Feeler I also installed a 2 port Quatech SDS (Serial Device Server) that sits in the machine cabinet. It is fed by an Ethernet cable and delivers RS232 signals to the CNC. I bought the DSE-100D model.
    http://www.quatech.com/pdf/sds.pdf
    It works well, but sometimes the transmission stops during machining and I do not know why? My question is: Can this server eliminate my ground loop issues with the new Feeler, since it is an Ethernet/serial adaptor? Or will the problems continue since it is not galvanically isolated?
    Oct 2005
    672
    The Exsys device will provide isolation from grounding issues. The Quatech device does not appear to have any isolation based on the description.
    On my mills, I use units from Betatronics to prevent ground loop issues and ensure more reliable transmission.
    Sep 2010
    1230
    Quote Originally Posted by Caprirs View Post
    I can't see that being a viable test. Unless the Shield Trace has been connected to the metal housing of the unplugged D connector, when its unplugged from the device, the metal housing is insulated from everything. I'd be inclined to do the test between the SG pin of the connector and the PC/CNC.
    Regards,
    Bill
    Oct 2005
    672
    That is a good point. I assumed the shield would be wired correctly.
    Jun 2008
    230
    The shield is not wired to any D-sub pin. It is only grounded to chassis frame very near the CNC control in the cabinet.
    Sep 2010
    1230
    Hi Caprirs,
    There is much discussion regarding grounding of the shield, but I note that the Pin Out schematic early on in this thread shows no reference to the shield being grounded. Accordingly, I assumed that the OP's cable may not have had the Shield Trace connected to ground, as is often the case. Its also often the case that the Shield Trace is connected to pin 1, Protective Ground, of a DB25 connector. Protective Ground on a DB9 connector is the metal housing.
    There are those that argue that the shield should be grounded at both ends (both devices), but to do so can lead to Ground Loops. As you no doubt know, a Ground Loop can occur when any two devices are grounded in Different Places, or if one device is not grounded well enough. For example, you may experience a ground loop when you connect a PC and a CNC control together with a serial data cable, if the CNC machine has a ground stake driven through the shop floor, and your Personal Computer is grounded via the ac wall socket, or if one device is not grounded well enough. The ground loop occurs when there is a different electrical potential between the Grounds of the two devices. This results in an electrical current being conducted through the data cable. and can burn out the IC chips that send and receive the RS232 serial signals, if the difference in potential is greater than about 30 volts. Accordingly, unless good grounding to the same ground can be assured for both devices, its recommended to ground the shield at the CNC end only.
    I've come in quite late on the Thread, but after the quick catch up read I've done, I concur with you that its a grounding issue. This is somewhat reinforced by the fact that the issue is there when the Lap Top is powered via a power supply plugged into a wall socket.
    Regards,
    Bill
    Jun 2008
    230
    Success!:cheers:
    Today I set up communication between the PC and CNC again, now with the Exsys RS232 Optical Isolator in between.
    It really cuts all galvanic connections and worked like a charm even at 19200Baud as I always use.
    The Isolator's 220V wall adapter use the same source as the PC.
    The cable between the PC and RS232 Optical Isolator.
    The cable between the RS232 Optical Isolator and CNC.
    Jul 2009
    219
    Glad to hear you have it working!
    Have you tried drip-feeding @ 19.2 or just loading programs?
    Jun 2008
    230
    On my other Feeler I do all machining by dripfeeding from a PC.
    I always use 19.2 KBaud Baud and it works really well.
    Will try dripfeeding the new Feeler soon, maybe tomorrow evening.
    I only store a tool offset measuring/editing program in the CNC.
    All CAM programs are stored in the PC + on a NAS disc.
  1. Ground wire
    By sodfarmer in forum Hypertherm Plasma
    Last Post: 04-27-2011, 12:47 PM
  2. servo amp signal wire
    By Karl_T in forum Servo Motors / Drives
    Last Post: 11-05-2010, 11:41 AM
  3. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  4. New Servo with ground wire
    By Larken in forum Automation Technology Products
    Last Post: 05-03-2007, 12:33 PM
  5. Motor supply ground vs Logic ground?
    By Gashmore in forum CNC Machine Related Electronics
    Last Post: 06-07-2005, 11:21 PM
