587,999 active members*
2,654 visitors online*
    Nov 2010
    31
    Star SR20R G112 HELP
    hI lads ,Ive just had G112 option enabled on my Star SR20R and Im trying to cut a "Torx" type fitting on the end of a screwdriver using a front Y axis milling cutter.I am trying to do the path incrementally using Y & for one section then repeating it 6 times to complete the shape .The manual is doing my head in can anyone help before I whack the machine with a large hammer ,cheers for any help
    Mick
    Jun 2010
    46
    What most people have trouble with G112 is the C axis as it is not radial axis but a linear (straight line) axis.
    Look at it as a X,Y application on a machining centre subsituting the X for C
    The other issue I find is the tool compensation when using this function is a pain in the butt.
    I always program the cutter path (centre of tool) as it is a lot easier
    If you look at the sample program in the star manual the Y axis is still treated as a diameter and the C axis linear is a radius axis.
    The C zero and Y zero is in the centre of the spindle
    Nov 2010
    31
    Thanks ,Im trying to use comp so may end up doing away with that and program the cutter path instead as you sugest ,I will have another few hours on it this morning
    Nov 2010
    31
    cracked it just wrote a subroutine starting with G112 and ending G113 and repeated it 6 times worked a treat ,now all I need to do is get TNR working
    Mick
  1. G112 for Okuma OSP700M
    By mobile61 in forum Okuma
    Last Post: 07-06-2010, 07:25 PM
  2. G112 NEED HELP TURNING ON PARAM
    By INXS in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-28-2008, 08:48 PM
  3. mastercam face contour g112
    By Mike68 in forum Mastercam
    Last Post: 06-27-2008, 03:28 AM
  4. Trouble with g112/g113
    By M-man in forum Mastercam
    Last Post: 02-12-2007, 08:54 PM
  5. G112
    By CatCAD in forum G-Code Programing
    Last Post: 12-04-2006, 11:12 PM
