588,340 active members*
4,976 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mastercam face contour g112
Results 1 to 8 of 8
    Jun 2008
    3
    Why mastercam do like this when i milling face contour on my lathe
    G50 X250. Z250.
    G0 T1000
    M35
    G0 X170.66 Z5.
    C354.958
    G97 S500 M54
    Z2.
    G98 G1 G112
    X170. Z-10. C-7.5 F50.
    G3 X185. C0. R7.5
    X170. C7.5 R7.5
    X155. C0. R7.5
    X170. C-7.5 R7.5
    G1 Z-8. F10000.
    Z2.
    X-170. C7.5
    Z-10. F50.
    G3 X-185. C0. R7.5 (this code is wrong x-axis is not move limit is 20mm)
    X-170. C-7.5 R7.5
    X-155. C0. R7.5
    X-170. C7.5 R7.5
    G113
    G0 X170.66 Z-5. C174.958
    your part may not be in the right plane. email your part I will look at it
    steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Jun 2008
    3
    T/c plane
    hi
    My T/C plane is Right side (lathe upper left)top 1)
    can you show me any code where lathe milling two circle (30mm) 180 degree angle. by using G112 command.
    Mike....
    can you send the part.
    steve
    [email protected]
    www.cad2cam.net
    T/C plane should be TOP not RIGHT. Post your file here so everyone can see it.
    Jul 2003
    263
    if you are on the main spindle WCS should be TOP ( +D+z ) tool plane and construction should be RIGHT SIDE and since you are using G112 your rotary axis should be set to C axis
    If you can ENVISION it I can make it
    Hail to the king!
    Sep 2007
    217
    Do you have your geometry broken so the post will do this correctly? If you go past center line on some post it will go crazy. Also if you do not draw your lines in the correct view and start and end them the right way the post will go crazy. Could send it over to Mike he would pop it in Catia in about 4 seconds.
  1. pocket first or contour?
    By thecoolsundar in forum Mastercam
    Last Post: 12-05-2007, 11:43 AM
  2. Trouble with g112/g113
    By M-man in forum Mastercam
    Last Post: 02-12-2007, 08:54 PM
  3. G112
    By CatCAD in forum G-Code Programing
    Last Post: 12-04-2006, 11:12 PM
  4. Machine in 3 axis durin g112 mode?
    By M-man in forum Fanuc
    Last Post: 07-23-2006, 02:39 AM
  5. angular contact bearings face to face??
    By powerfade in forum DIY CNC Router Table Machines
    Last Post: 06-19-2005, 05:01 AM
