587,753 active members*
3,041 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Wiring digital driver to BOB?
Page 4 of 4 234
Results 61 to 72 of 72
  1. #61
    Sep 2011
    474
    Quote Originally Posted by 109jb View Post
    Both wiring options are valid depending on the BOB you use, but for the BOB you said you have it should be wired like this picture that is in the KL-5056D manual that you can download from the following link:
    http://www.automationtechnologiesinc...load.php?id=51
    Alrighty, done. Now it goes very slowly and in one direction only. GAH!
    Any other ideas?
    Edit: I set Step Low Active and Dir Low active and now it turns both ways but VERY slowly. I have it set to 2 microsteps and 4000 steps per inch, though it doesnt seem to matter. Even at 10000 steps per inch it crawls along. Could it need a resistor as in the diagram?
  2. #62
    1943
    What control software are you using? The manual says you need a minimum 2500 nano-second step pulse and a minimum 2500 nano-second low level width. If using Mach 3, try Sherline 1/2 pulse mode under Config/Ports and pins.
  3. #63
    1943
    Also in "config/motor tuning" set step pulse to 5 and direction pulse to 5
  4. #64
    Sep 2011
    474
    Ok, I switched on Sherline 1/2 step mode and it turns in one direction only again. It does seem a touch faster though. What is the "nanosecond low level width"? Can I check this? And yes, im using Mach 3.
    Thanks!
  5. #65
    1943
    Quote Originally Posted by SwampDonkey View Post
    Thanks!
    Basically, the step pulses work between +5 and 0 volts. The pulse width is the length of time when the signal is +5V. The low level width is the length of time when the signal is 0 volts. As I understand it, the Sherline mode forces the low level signal to be the same as the pulse signal.
    The step pulse width and direction pulse width are defined on the motor tuning page.
  6. #66
    Sep 2011
    474
    Well, everything is as it should be. The thing doesnt work. I guess I'll try to call AT support tomorrow and if they cant figure it out I'll send it back and try to get a refund. Wow, this is terrible. Ive wasted a month messing with these KL5056's and will have to wait another month to get a new driver from China.
    Thanks for all your help! If you can think of anything else that may be an issue, please let me know. I would much rather use the driver I have on hand
  7. #67
    1943
    Have you tried wiring to an axis on the BOB that is known to work?
  8. #68
    Sep 2011
    474
    Yes, ive tried all sorts of combinations. It has the same effect on whatever motor/ axis its driving.
  9. #69
    Sep 2011
    474
    Quote Originally Posted by Bruce323 View Post
    that's what i was hoping for.
    Can you elaborate?
  10. #70
    Jan 2010
    2141
    This is just a wild guess (and maybe you've already tried it - I haven't gone all the way back to re-read this thread).
    Is it possible that you have set the DIP switches to the opposite direction of what you intended, so that your "on" switches are actually "off" and vice-versa?
  11. #71
    Sep 2011
    474
    Quote Originally Posted by doorknob View Post
    Nope, tried and checked that. I called John at AT customer support and he doesnt seem to know what the problem is either. Im going to send him some pictures of the set-up and hope that helps solve the mystery.
    Editfairly bad) video here:
    [ame="http://http://www.youtube.com/watch?v=EXmHdW7Psok"]http://http://www.youtube.com/watch?v=EXmHdW7Psok[/ame]
  12. #72
    Nov 2014
    20
    Re: Wiring digital driver to BOB?
    Whatever happened with this problem? I have the same exact issue going on.
Page 4 of 4 234
  1. Digital tool dr902 wiring diagram
    By brockadeau in forum BobCad-Cam
    Last Post: 10-20-2014, 01:51 PM
  2. Keling Digital driver problems
    By 996pilot in forum Stepper Motors / Drives
    Last Post: 01-12-2013, 12:25 AM
  3. digital stepper driver recommendations
    By dsnaith in forum Stepper Motors / Drives
    Last Post: 11-30-2012, 10:50 PM
  4. Digital Stepper Driver
    By kolias in forum Open Source CNC Machine Designs
    Last Post: 03-08-2012, 02:03 PM
  5. Can you pulse a digital driver manually?
    By Fastest1 in forum Stepper Motors / Drives
    Last Post: 08-18-2011, 06:35 AM
