I have a J325 1990yr model. Delta 20 contol.
I can reference all the axis. Afterwards the X and Z move in the correct direction according to the control. The Y axis on the otherhand, when reference moves only toward the column or in the negative direction. I am not very far away from the column so i dont move it far in fear of breaking or damaging anything. When I try to move in in the postive direction( or bring the the table out futher on the knee) I get a y axis fault.
Is there a setting that needs to be changed to get it to function properly? It almost seems as if one of the parameter needs to be changed for direction or a soft parameter needs to have the numbers changed.
I should add, I just recieved this mill, and got it hooked up. So still getting familiar with the control.
Thanks for anyhelp.
