Have an 8025T on a Hardinge lathe. Runs great but have come upon a seemingly simple situation that I don't know the answer to. I have a 4" length of 2"OD material in chuck. Have to turn OD, drill and bore ID, part off, then do again 5 times to make 5 spacers each .7" wide. I want to program this for one part, then have the Z axis move toward the spindle the required distance then run program again and again until all 5 parts done. I am using G90, G95 for each tool. How do I do this without manually programming all the different Z data for each of the 5 parts? Must be a way to offset this thing each time and use the same numbers?? Thanks for any info on this. Russ
