I use Gerry's Mach3 2010 layout for it's concise use of screen space and having most of the functionality I need right there on one screen. I say "most" since I frequently use the probe screen.
Well worth the price.
Stock Install
Mach Blue Probing
Mach3 2010
Touch screen
PBJ ScreenSet 2012 for Mill
Other
CRP-4848 CNC Router, CNC G0463 (Sieg X3) Mill, 9"x20" HF CNC Lathe (current project)
Even thou I own Gerry's Mach3 2010 screen , must say my favorite is the Aqua screen produced by the same guy ..
Forget about global warming...Visualize using your turn signal!
Gerry's Mach3 2010 screen , It works well and looks good.
I use MSM from Calyspo Ventures Software for the mill and lathe. Will be experimenting with Mill Turn (Using the Mill as a Lathe) as soon as I have finished fabricating the tooling for it.
The following link will take you to my experience with MSM and has numerous screen shots of the screens. Not just another screen set, numerous add on features such as virtually any probing routine you might need, expanded tool table, master tooling etc. etc.
http://www.cnczone.com/forums/screen_layouts_post_processors_misc/152066-machstdmill_turn_mill-turn_announcement.html
The following link will take you to Calypso Venture's web page, click on Digital Machinist articles.
http://api.viglink.com/api/click?format=go&key=8fc203c6d53cfcf639464b616dec43 af&loc=http%3A%2F%2Fwww.cnczone.com%2Fforums%2Fscr een_layouts_post_processors_misc%2F152066-machstdmill_turn_mill-turn_announcement.html&v=1&libid=1360387441350&out =http%3A%2F%2Fwww.calypsoventures.com%2Fmachstdmil l%2Foverview.html&ref=http%3A%2F%2Fwww.cnczone.com %2Fforums%2Fscreen_layouts_post_processors_misc%2F &title=MachStdMill%20Turn%20and%20Mill-Turn%20Announcement%20-%20CNCzone.com-The%20Largest%20Machinist%20Community%20on%20the%2 0net!&txt=Calypso%20Ventures%2C%20Inc.&jsonp=vglnk _jsonp_13603875366374
John
I also use MSM from Calyspo Ventures. Not only does it make Mach easy to use, the probing routines and support for multiple tools is top notch.
+1 for Gerry's 2010 Screen Set. Best software money that I ever spent. Also excellent customer support. A sound product that runs without glitches.
I customized mine slightly with some help from a friend to suit my personal needs.
John
2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
I run a Tormach PCNC 1100 with ATC. Wrote my own screen set, well modified the original one to make setting tool height real easy, setting X and Y zero real easy and added a much needed part counter. I Googled and didn't find much in the way of helping me with the part counter so if anyone is interested in knowing how to add a part counter into Mach 3 screens hit me up.
