588,137 active members*
5,557 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V25 : Setting up a 4 axis cnc router ( B Axis ) on the Z
Results 1 to 5 of 5
    Mar 2012
    1570
    Hello Everyone,
    So this is the first machine that I've setup using the BobCAD CAM V25 software. I had to setup the machine to support a B axis rotation on the Z slide of a 4 axis cnc router. I walk through the setups of setting up the machine definition ( at some point I want to show how to design and load the stl modes for full machine simulation ) loading a solid and programming the part using our multi axis wire frame tool path, posting in 4 axis.
    So check it out and let me know what you guys think!
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Mar 2012
    1570
    Next I need to create a video showing how to load the files for full machine simulation !!!!!
    Al DePoalo
    Mar 2012
    1570
    Well I did it!
    Al DePoalo
    Mar 2012
    1570
    Here the video is showing the machine simulation:
    Al DePoalo
    Feb 2009
    2143
    Very cool, Al! Just got in a 4th/5th for my mill. Need to add a controller for the 5th, and get it all wired up, and then I'll be giving y'all a call!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  1. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
  2. 4-axis mill post and a-axis datum setting
    By inflateable in forum EdgeCam
    Last Post: 02-09-2011, 09:35 AM
  3. 3 projects of CNC Router 3Axis, 4 Axis and 5 Axis
    By LuthierX in forum Uncategorised MetalWorking Machines
    Last Post: 07-07-2008, 02:26 AM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
