588,173 active members*
4,236 visitors online*
Thread: OSP700L
Results 1 to 16 of 16
    Jun 2009
    108
    OSP700L
    Hello!
    Someones knows how change the configuration chuck, as spindle or as axis, because after charge all software, we can't run the spindle or chuck 850 RPM more, the control is OSP700L but I don't have some manual to know what parameter must modify to increase the spindle speed.
    Aug 2011
    2517
    that speed could be the limit for the gear you are in. try changing to high gear.
    Jul 2011
    At the MDI function try key in M3 S850 M42 then follow by cycle start.
    Jun 2009
    108
    Quote Originally Posted by fordav11 View Post
    How change to high gear?
    With M42 ?
    Mar 2009
    1982
    M40 neutral, M41 slowest, M42 middle, M43 high (if your machine has three of them)
    Jun 2009
    108
    Quote Originally Posted by Algirdas View Post
    M40 neutral, M41 slowest, M42 middle, M43 high (it your machine has three of them)
    Thnks a lot for your help!
    Regards!
    Dec 2011
    8
    Hi ALL!
    I have the issue with this model!
    First, i want to change battery and power on
    Alarm: 128 Memory disk format!
    Please help me to solve this Problem
    thank you verry much
    Mar 2009
    1982
    1. change the battery. Do it smart way: connect additional power supply in parallel first and only then replace the battery. Otherwise you'll need a special procedure.
    2. re-install the software. there is something wrong.
    Dec 2011
    8
    THANK YOU ALGIRDAS
    -now I do not have the disk in the machine, not the other way
    please specific guidelines that must be how my half
    I do not know much about Okuma
    please help me
    thankkkkkk......
    Mar 2009
    1982
    can you descrbe more specific, when do you get the message
    are you sure, it's just "Alarm"? Isn't it "Alarm P" or "Alarm A" or somethong like?
    Dec 2011
    8
    HI ..ALGIRDAS
    when I open up the source of the display as shown below
    forward to help
    Sorry for my english slightly less
    Attachment 200914
    Aug 2011
    2517
    That's a serious problem. your machine is not even working or booted up properly.
    As a minimum you need to re-install the system software from your floppy disks.
    If you don't know how to do that or you don't have the floppies you need to contact Okuma for professional assistance.
    Dec 2011
    8
    OK THANK YOU ......FORDAV11
    Such problem is that I did not have a system disk
    I know that someone will find this disc where no
    I would buy this disc and the way my Okuma machine operators
    * I honestly grateful for the help of your enthusiasm
    good fun
    Mar 2009
    1982
    illustration is good.
    so, your control doesn't start booting, as Mr.fordav11 noted already. You have SBP monitor message.
    SBP monitor is tiny small program which checks hardware before operating system boot. Memory detection is the first checkpoint when CPU is powered and clocked.
    You have an error on 0000 address on the very first step of hardware check.
    There are two places to check first:
    1. Control rack. Check if there are no error indication on Opus face panel
    2. Control set. Some modules are missing or faulty.
    Generally saying you're in deep deep crap without installation media and proper Okuma support.
    The reasons of condition like that could be:
    1. Uncompleted/ improper reinstallation of Okuma operating system.
    2. hardware fault.
    3. missing module (most likely at this case)
    Dec 2011
    8
    hi..algirdas
    number (0000) is not your fault, that they entered a try nothing changes
    sorry for not saying this before
    Mar 2009
    1982
    Quote Originally Posted by mrphuocauto View Post
    it indicates the initial fault of test. memory test is the very first one in the test sequence. So, your control is faulty at the very start of tests. By the way, when you contact Okuma support, tell them, that you have alarm "106" on memory test test block "0000" in SBP monitor
  1. Turning Okuma OSP700L Alarm 128!
    By kakashi in forum Okuma
    Last Post: 04-11-2022, 07:45 PM
  2. Backing Up Parameters? (OSP700L)
    By H234 in forum Okuma
    Last Post: 10-11-2020, 09:25 AM
  3. OSP700L questions
    By ZLEB in forum Okuma
    Last Post: 06-24-2010, 11:37 AM
  4. Replies: 9
    Last Post: 06-09-2009, 11:47 PM
  5. Setting up Tools - OKUMA OSP700L
    By hiatec in forum Okuma
    Last Post: 03-19-2008, 12:51 AM
