603,365 active members*
2,661 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 3D toolpath strategy advice !!
Results 1 to 11 of 11
    Oct 2006
    259
    Superman as always....to the rescue :-)
    Sound like a good approach....except, in this particular file, I do not have a 3d center line ?...it's imported from a DWG and for some reason, I can't "grip" to some lines allowing me to add one !?
    BUT.....by using the surface rough pocket then fallowed W/ surface finish blend with a step over (15%)....it look ....ok !?
    still "playing" with this and some other alternatives !!
    But ( another but !) ,,,,I still would like to here some other alternatives....as I'm certain MC can offer me ( for this case and further ones) various ones ?? ( maybe art ?)
    Sep 2012
    1195
    Using a centerline to drive the tool will only work if the radius is the same from end to end. To my eye, it looks like the radius varies from one end to the other (basically conical), in which case it will need to be done via 3d toolpath. What strategies do you have available?
  1. What strategy to use here?
    By BTP in forum Mastercam
    Last Post: 04-19-2013, 04:58 PM
  2. Advice on machining strategy
    By xj5373 in forum BobCad-Cam
    Last Post: 10-28-2011, 07:16 PM
  3. Hold-down strategy
    By revwarguy in forum DIY CNC Router Table Machines
    Last Post: 06-02-2010, 08:38 PM
  4. Strategy
    By Pierre Phe in forum CNC Machine Related Electronics
    Last Post: 06-06-2003, 07:14 PM
