603,848 active members*
2,865 visitors online*
IndustryArena Forum > CAM Software > Mastercam > What strategy to use here?
Results 1 to 6 of 6
    Jan 2012
    139
    I'm having a little issue figuring out the best strategy to use on this part. Basically I want to face the ledge top surface (highlighted in blue) and leave enough to come back and finish the small step (wall) to the left. Any suggestions are helpful.
    Dec 2008
    717
    I am not seeing the difficulty...
    Tim
    Jan 2012
    139
    When I use a simple contour with multiple passes it works okay except when I go to cut the left island it wants to to cut into the right island. Is there any way you can have it only extend beyond a selected boundary?
    Dec 2008
    717
    Sometimes you need to create additional geometry to use as your toolpaths. In this instance, you may want to create the lines parallel to the main wall that you want to cut but shorten them at the end so they don't gouge the other island.
    You can also copy the edges to a different level, offset them a little so you cut over the edge but leave the wall line where it is then just trim the offset edges to the wall edge and use a pocket routine.
    There are a few different ways to get this and they will only take a minute to accomplish.
    Tim
    Jan 2012
    139
    Sorry about that I had a brain fart. I used the contour offset and then pocketed it out. I've actually done this before but forgot my method. All is good. Thanks
    Apr 2003
    3578
    If you share your file I can do it without having to make any extra geo.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Hold-down strategy
    By revwarguy in forum DIY CNC Router Table Machines
    Last Post: 06-02-2010, 08:38 PM
  2. To choose strategy
    By goodillla in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-19-2009, 07:38 AM
  3. Strategy Manager
    By robyc01 in forum EdgeCam
    Last Post: 06-27-2009, 09:25 PM
  4. Strategy
    By Pierre Phe in forum CNC Machine Related Electronics
    Last Post: 06-06-2003, 07:14 PM
