Hi all is anyone know how to prevent lower case letters and special characters in G code
What do you mean by prevent? It's should be part of your code and there are lowers and uppers to help us.
Sent from my Nexus 4 using Tapatalk
What I mean is that my machine won't accept lower case letters so I want all my comments and instructions in the G-code become upper case . Is there anyway to do that ?
If you can edit in wordpad, you can cnrl-a that is select all and change the your fonts to lower case.
You can edit your gpp file to convert all letters to lower or uppercase. Try this
string_variable = upper(string_variable)
The upper function did it
