Hi...
So the following scenario happened.
Someone forgot to change the batteries from the Leadwell GMC-600 with Fanuc OMC and all the parameters were gone...
Luckily we had very old backup in tape but it lacks some parameters, cause with these parameters the ATC won't work with M6 or T command.
When we send the tool change command with T0 => Machine gives the error about tool no being 0 value.
But any other then 0 as tool change number it gives the "Error 1039 Tool no > 16"
Which would mean that the machine has lost ATC index position parameter or counter parameter, but we have no info from where it is located.
What works and does not work on ATC:
Manual rotate switch CW: No
Manual rotate switch CCW: Yes
M11 (Rotate ATC CW) : Yes
M12 (Rotate ATC CCW) : Yes
M6 T0 : Error tool no = 0
M6 Txx : Error 1039 Tool no > 16
Any help is much appreciated
