588,366 active members*
6,491 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > TB6560HQ-Stepping Motor Driver IC 3.5amp
Page 14 of 14 4121314
Results 261 to 272 of 272
  1. #261
    Christopher01 Guest
    I have a stepping motor that i can't seem to get working.i'm going to list everything that is on the label.Stepping motor,Mitsumi,
    i'm not to exicited about buying a driver for it. I am looking USEFULL information.
  2. #262
    Oct 2012
    hello folks are you all still active on making this?
    Quote Originally Posted by lucas View Post
    there are 2 versions of "my design".
    The first one has jumpers for all options (torque and decay control), these have been removed on the lastest version.
    I still have one problem: on the first version the motor is noisy (hissing) and completely silent on the second version, I don't know why:
    PCB design, the different type of current sense resistors I used or the removed option jumpers.
    I don't have pcb's of the second version but have a few of the first one.
    I really need some time to investigate the noise disappearence by swapping components.
    Which motors do you have, output current required? Also wich power supply do you intend to use?
    My design is really simple but needs an optically isolated BOB (designed my own matching these drivers :-) ).
    Are you in a hurry? : I will make a new batch of the second version in the near future but can't say when.
    Regards,
    Luc.
  3. #263
    364
    The TB6560 has some design flaws and fails regulary due to a "complex" power-up sequence.
    I've used it since it was introduced and have 2 machines using these without problems.
    You can see a pic of my latest design here: http://users.skynet.be/ldt/CNC%20ele...B6560_assy.jpg
    I currently don't offer a kit but if you want some please contact me.
    The spec's of this chip are far inferiour to the THB6064 but the chip is cheaper and so is the rest of the parts, this results in a much cheaper drive for low power motors (24V supply and 2.5Amp current, these are the safe settings). I will still use it for these specific situations.
    If you need a cheap DIY drive with some reserve for upgrades in the future: have a look at the 3 THB6064 designs (40V supply and 4Amp current, safe settings also).
  4. #264
    Oct 2012
    aha ... that is nice ... i am just looking for some alternative to A4988
    my steppers are rated 10V and 0.9A @ 59oz/in
    so these TB6560AHQ, i assume they are the same made in china?
    i am looking to make some experimental drivers that have drive PWM in the region of 100-200kHz clock.
  5. #265
    May 2005
    1397
    Quote Originally Posted by whitelabs View Post
    For those motors, I would strongly suggest the Linistepper. Even the TB6560 is overkill for that motor, and will (as Luc said) NOT be reliable.
    Stepper Motors
    More than enough power for your motors, as supplied with the kit, and you can order replacement drive transistors for a few dollars if you fry them.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  6. #266
    Oct 2012
    hmmm linsteppers ...
    A4988s are cheap, $7.50 for a full board plug and play.
    i am past that and going to the part of driving a stepper motor custom to its ability/characteristics. this is the part where ppl are saying does your motor whine, miss steps etc.
    the reason i fried 4 is because my hand moved ... and the probe shorted the SMD 4 times hahahahaha ! stupid SMDs!!!
    i find that the best advantage of the 6xxx chips are the ability to sink larger amts of heat compared to 8825s (or any SMD,Fxx,etc). but to a builder like me, larger parts = easier to solder ... instead of trying to pick up SMD with my big thumbs lol.
  7. #267
    May 2005
    1397
    A4988s are cheap, because they are low power chopper drivers. The Linistepper provides more power, and isn't a chopper, so there is ZERO whine. You can find links to videos on the site if you want to hear it. And the kit is entirely through hole parts, nothing closer than 0.1" and a very professional, easy to solder PCB. You can also buy just the PCB, and download the program for the PIC, if you have a PIC programmer. It's open source.
  8. #268
    Oct 2012
    ahhh ... im already on the arduinos ....
    yea the A4988 boards are so tiny ... thats why small little hand shake and pooof my scope probe has wander off to another track and shorted some **** LOL.
    aha non choppers, i wonder how that scales in terms of fitting drive to motor like a glove. i dont think it accepts a drive logic like arduino ... (cw/ccw, step, enable?)
    tnx for the info anyway
  9. #269
    Mar 2007
    8
    Hi...
    I was browsing through this thread and found this Toshiba 6560AHQ
    It seems like one of the easiest and simplest, and as it is pminmo desing it seems like good driver.
    Anybody was doing this at home ?
  10. #270
    thanks
  11. #271
    Re: TB6560HQ-Stepping Motor Driver IC 3.5amp
    merciiiiiiiiiiiiiiiii
  12. #272
    Mar 2015
    thanks
  1. THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 10-03-2014, 12:52 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
