Application:
Series KPH transformer oil regeneration device use of a special active clay for purifying and regenerating the unqualified transformer oil, switch oil, mutual inductor, it also can be used as absorption unit for treating low viscosity lube oils. Series KPH can remove acid, free carbon, oxides, pigment and particles, it dose not affect insulating oil ingredients and anti-oxidation. Restoring oil dielectric strength, the treated oil is limpidity. It can save 90% cost than replacing of new oil.
KPH is mainly to regenerate the old insulating oil, it remove acid, sludge, oxidation and various of resultant, the treated oil is limpidity and clarity color. After the regenerating process, we suggest to use the vacuum insulating oil purifier to purify regenerated oil, remove the trace water, gas, and tiny particles. Getting more higher dielectric strength.
Regeneration Machine Features:
1.Use of special chemicals to eliminate oil-ion’s charge polarity, collecting oil-ions and separating out them, removing colloid, asphalt and other chemical compounds.
2.Gas treatment device combined with air filter and vacuum degassing, dewatering to remove the odor and water.
3.Closed type filtering system use stainless steel mesh, reliable, no pollution. Two filtering units can realize continuous production.
4.Vacuum degassing, dewatering, removing particles make sure effectively improve oil properties, restoring oil performance.
5.Efficient electric heating system, heating uniformity, less power consumption, safe, and reliable.
6.Compact structure, reasonable layout, small space applied, large output.
7.Imported Germany electric parts (such as SIEMENS, SCHNEIDER), good performance, safe and reliable.
