Hi ! How to edit subroutines on Fagor 8055T?
Editing subroutines is quite easy. They are created within part-programs and edited the same as a part program would be. You simply have to find where the particular subroutine is within memory and then where in that particular program. This is easily accomplished within the search function within the edit mode.
I do not have a manual set in front of me, but going out of memory, the code that starts a subroutine is G20, and the end of sub is G24.... (Check your manual to verify my codes, which can be found in the download section at www.fagorautomation.com if you do not have a manual printed copy)
Thus, an example subroutine would be:
N50 G20 N10 (This states this is the start of Subroutine 10)
N60 G90 Z0
N70 G0 X0 Y0
N80 M30
N90 G20 (This states the subroutine is over)
Edit the above just like a part program. As a note, most programmers will follow the idealogy of keeping your subroutines all within a protected part-program that has been appropriately named as a Subroutine program. Thus, you can have all frequently used subs in a single program for easy editing.
I hope this helps ! And certainly feel free to contact the Fagor Automation Service department for additional assistance.
Todd
Postprocesor for Fagor 8055iT MILLTurn
https://plus.google.com/105900927916224167149/posts
