588,293 active members*
5,436 visitors online*
Thread: CAMWORKS
Results 1 to 10 of 10
    Aug 2012
    CAMWORKS
    BEEN USING CAMWORKS FOR ABOUT 5 MONTHS NOW AND I'M ALMOST A EXPERT AT IT. :banana:
    Sep 2012
    Hey thats great, I have a ?, how do you set your postprocessor to generate code for a haas machine?...MAtt
    Aug 2012
    Quote Originally Posted by willow58 View Post
    Hello Matt, I have all Haas machines here. First you have to have the right post processor for Haas machines. If you double click on your machine in camworks you will see your tool crib, Post etc. Click on your post and see if you have a processor in there.
    Sep 2012
    Yes I go into the machine and all I see is example machines, is there some kind of database I can load to give me more machines?
    Aug 2012
    Do me a favor and click on your toolcrib and check to see if it is in mm. But yes you have to add you machines to the data base but first check your tool crib.
    Sep 2012
    All of the tools look like they are in inches. I do have 4 cribs: 1crib, 2crib(fadal), 3crib(haas), 4crib(english).
    Aug 2013
    any posts for a Haas lathe?
    bobcad guy Guest
    ive been "camming" about 2 weeks now. only done about 5 or 6 jobs. first 2 or 3 I sat in with a guy to learn. now i'm on my own, and I can handle the simple parts with no trouble. im sure trouble is right around the corner though, as the complexity of parts starts to increase. we do a lots of mold work, and 3D toolpaths, so the ripping of hair from my scalp is approaching.
    kingrais Guest
    I think rapid Prototyping can be defined as a group of techniques used to quickly CNC machines use CAD & CAM software that lets you easily switch between tasks by simply by loading a different program.
    Sep 2010
    16
    Re: CAMWORKS
    Working in Soliworks, you can go to the Camworks in toolbar and open technology database wich opens the database in microsoft access.
    In there you can add your machine and all relevant data, table dimension,travel,max rpm's etc. Later that machine is available to you in camworks.
  1. Camworks
    By Lootner in forum CamWorks
    Last Post: 02-05-2013, 11:01 AM
  2. camworks
    By rc-intx1981 in forum CamWorks
    Last Post: 04-06-2012, 07:09 AM
  3. CAMWorks 09 is out!!!
    By mdlmkr in forum CamWorks
    Last Post: 05-22-2009, 05:10 PM
  4. Camworks 3D
    By bobborck in forum CamWorks
    Last Post: 07-11-2008, 07:20 PM
  5. CAMWORKS
    By jprado in forum Spanish
    Last Post: 05-04-2008, 04:45 PM
