603,946 active members*
2,505 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller & Computer Solutions > CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
Results 1 to 20 of 35
teglberg CNC Lathe controlled with... 09-25-2014, 08:58 PM
Tkamsker Re: CNC Lathe controlled with... 09-25-2014, 09:45 PM
Al_The_Man Re: CNC Lathe controlled with... 09-25-2014, 09:50 PM
teglberg Re: CNC Lathe controlled with... 09-29-2014, 07:09 AM
Al_The_Man Re: CNC Lathe controlled with... 09-29-2014, 02:33 PM
teglberg Re: CNC Lathe controlled with... 09-29-2014, 07:06 AM
Tkamsker Re: CNC Lathe controlled with... 09-29-2014, 07:09 AM
teglberg Re: CNC Lathe controlled with... 09-29-2014, 07:48 AM
teglberg Re: CNC Lathe controlled with... 10-06-2014, 07:01 AM
Al_The_Man Re: CNC Lathe controlled with... 10-06-2014, 03:22 PM
Tkamsker Re: CNC Lathe controlled with... 10-06-2014, 03:45 PM
teglberg Re: CNC Lathe controlled with... 10-07-2014, 10:10 AM
teglberg Re: CNC Lathe controlled with... 10-17-2014, 05:22 PM
Al_The_Man Re: CNC Lathe controlled with... 10-17-2014, 05:41 PM
teglberg Re: CNC Lathe controlled with... 10-17-2014, 06:18 PM
Tkamsker Re: CNC Lathe controlled with... 10-17-2014, 07:32 PM
teglberg Re: CNC Lathe controlled with... 10-18-2014, 02:36 PM
Al_The_Man Re: CNC Lathe controlled with... 10-17-2014, 07:34 PM
teglberg Re: CNC Lathe controlled with... 10-17-2014, 08:02 PM
Al_The_Man Re: CNC Lathe controlled with... 10-18-2014, 01:13 AM
Tkamsker Re: CNC Lathe controlled with... 10-18-2014, 07:39 AM
Tkamsker Re: CNC Lathe controlled with... 10-18-2014, 08:09 PM
teglberg Re: CNC Lathe controlled with... 10-19-2014, 10:24 AM
Tkamsker Re: CNC Lathe controlled with... 10-21-2014, 07:38 AM
teglberg Re: CNC Lathe controlled with... 10-21-2014, 02:33 PM
teglberg Re: CNC Lathe controlled with... 10-22-2014, 11:12 AM
Tkamsker Re: CNC Lathe controlled with... 10-22-2014, 01:14 PM
teglberg Re: CNC Lathe controlled with... 10-24-2014, 09:12 AM
Tkamsker Re: CNC Lathe controlled with... 10-24-2014, 09:25 AM
teglberg Re: CNC Lathe controlled with... 10-24-2014, 09:30 AM
teglberg Re: CNC Lathe controlled with... 10-30-2014, 08:21 AM
Tkamsker Re: CNC Lathe controlled with... 10-31-2014, 06:13 AM
teglberg Re: CNC Lathe controlled with... 10-31-2014, 07:36 AM
Tkamsker Re: CNC Lathe controlled with... 11-01-2014, 09:09 AM
teglberg Re: CNC Lathe controlled with... 11-11-2014, 12:33 PM
    Dec 2003
    24260
    Re: CNC Lathe controlled with OLD! PC, can I change the PC and SOFTWARE??
    There are a few ways you can go, the PC you have is a ISA bus now legacy items, I would guess the DB44 is on a I/O card from one of the popular manuf of the time, if so it is ISA bus oriented and will not work with a later P.C.
    You may want to look at Mach3, Linux or kanalog for a new system.
    What type/make of motors and drives do you have? What was the old control s/w called?
    Al.
    Albert E.
    Sep 2014
    51
    Al.
    Can't tell you much details since it's stored somewhere else for now... anyhow I'm not sure I know what you're asking?
    Dec 2003
    24260
    Quote Originally Posted by teglberg View Post
    Make or name of controller on the machine.?
    Al.
    Albert E.
  1. Find Software for Z zero after tool change
    By Mr.Chips in forum Calibration / Measurement
    Last Post: 01-12-2012, 03:31 AM
  2. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  3. I want to change my software ?
    By eng_semsem1980 in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-10-2007, 06:36 AM
  4. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  5. Software change request
    By widgitmaster in forum Mach Software (ArtSoft software)
    Last Post: 11-26-2005, 03:38 AM
