587,837 active members*
3,422 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Work Transfer Doosan - Puma TT 2000 SY
    Sep 2014
    7
    i need to trasnfer workpiece on TT2000SY (fanuc 18i) from one spindle to the second spindle with "overload stop" in manual its called "torque skip".
    I can trasfer it. But i really need that overload. In manual is this :
    M131 ; Rotate right spindle under the unclamp state of right chuck.
    M169 ; Unclamp right chuck.
    M203S_ ; Synchronizing left spindle and right spindle, rotate to CW direction.
    G00 A_. ; Move right spindle to the front of left spindle using A-axis.
    M86 ; Activate the torque skip function.
    G31 P98 A_. F_ ; A-axis is moved by the commanded feed, left spindle and right
    spindle is adhered, and if A-axis is carried the load (torque) more
    than the setting value, stops the movement of A-axis and executes
    the next block
    M87 ; Make the torque skip function unavailable.
    M168 ; Clamp right chuck.
    M31 ; Left chuck can be unclamped during the rotation of left spindle.
    M69 ; Unclamp left chuck.
    G00 A_. ; Move A-axis for next cutting.
    I tried it but it didnt stop on that "overload". In manual there is a note: It is normal to programming move 2-4mm behind "adhere point". I tried move it 0.3 behind and it wont stop.. Im afraid go far.. for example 2mm.. i dont want crash it..
    So does have anyone some experience with it and can help me? it is very important :X
    thanks for response
    P.S.: sorry for my bad english
    Jul 2005
    380
    Re: Work Transfer Doosan - Puma TT 2000 SY
    Hi
    What's the serial # on the machine?
    I can help.
    Jul 2005
    380
    Make sure there is a "M86" Torque Skip command function activation on a line by itself BEFORE the G31 and a "M87" Torque Skip Command Cancel on a line by itself AFTER the part hand off. This should help.
    Sep 2014
    7
    Its working thanks for answer.. i programmed 3mm behind and it stops cca 0.4 - 0.6 behind adhere point.. i can even watch % overload of axis..
  1. Need help with my doosan puma 400 m
    By gongo999 in forum Daewoo/Doosan
    Last Post: 12-06-2014, 02:15 PM
  2. Help with doosan puma 300 lb
    By mattlynx in forum Daewoo/Doosan
    Last Post: 12-04-2013, 09:56 PM
  3. Doosan Puma 400L
    By Bada Bing in forum Daewoo/Doosan
    Last Post: 06-05-2013, 12:43 AM
  4. Doosan Puma 2100SY
    By Mikey4865 in forum Daewoo/Doosan
    Last Post: 01-29-2013, 08:37 PM
  5. Doosan - Puma 240S
    By dartplayer1 in forum Daewoo/Doosan
    Last Post: 09-25-2012, 12:50 PM
