588,357 active members*
8,539 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Plow through wall
Results 1 to 19 of 19
    Dec 2012
    57
    Plow through wall
    Why does the cutter plow through the wall ?
    I am pocketing these letters. you can see where the cutter plows through the wall
    As far as I can tell the curves are closed.
    ANSWER
    edit note. Joakim " cut link distance must be set lower than the diameter of the bit". Find this pop up in Cutters under the tab Other.
    Please help thank you
    Ken
    Dec 2012
    57
    Re: Plow through wall
    RAttachment 264690
    On a related note.
    When I try to pocket these closed curves within the model if I choose them all routes through the walls.
    But if I select them individually the toolpath is okay
    I remember hearing about this problem.
    I must have something set incorrectly please help
    Ken
    Apr 2003
    1357
    Take a look at the post called "Collisions in Simulation" just a couple below. Take a look at the video Sven posted. This might be helpful.
    Dan
    Dec 2012
    57
    I will do that now.
    Ken
    Dec 2012
    57
    Attachment 264698
    I created an offset curve and extruded it. I used that curve fo the boundry. Same problem.
    Ken
    Dec 2012
    57
    I really want this to work. It seems overly complicated.
    Ken
    Dec 2012
    57
    Why do I even need a region curve? Why can't the cutter stay inside the curve to rout the pocket. A pocket is never two things, just one pocket.
    Dec 2012
    57
    These region curves are about as secure as the US border
    Ken
    Apr 2003
    1357
    Can you post the file? It does seem overly complicated. This should be easy.
    Dec 2012
    57
    Quote Originally Posted by Dan B View Post
    What format for the file is best for this forum. I can email a rhino file if you can receive.
    [email protected]
    Dec 2012
    57
    No luck. I worked on this problem several hours today.
    Ken
    Dec 2012
    57
    Ken
    Dec 2012
    57
    Plow through wall
    I sent the file to the one who took my $750.00.
    Edit. I apologize for my comment.
    Ken
    Mar 2004
    1661
    Quote Originally Posted by dotmkr View Post
    Ken
    <irony>Yeah, it's probably not a user problem.</irony>
    You have already been asked to post the file and that it is the least you can do to get help here.
    Apr 2003
    1357
    Hi Ken,
    I sent you an e-mail. Please send me the Rhino file and a description of the tooling you are using. I want to see if I can replicate your issues.
    Also, some screen captures of your inputs would be helpful too.
    Thanks,
    Dan
    Dec 2012
    57
    Joakim responded to me with an email.
    His answer was as i suspected. I had a setting that was causing the cutter to plow through.
    Ken
    Dec 2012
    57
    Cut link distance should be set lower than the cutter.
    Ken
    Dec 2012
    57
    And so now the cutter stays inside the the lines. There are no region curves set.
    Ken
    Dec 2012
    57
    Plow through wall
    Attachment 264812
    Pretty good outcome. Some weirdness when the bit first enters the cut at the start of the M. I think this can be fixed by setting ramp to zero. It will get sanded away.
    Ken
  1. Wall bugs
    By skylanehku in forum CNC Machine Related Electronics
    Last Post: 09-28-2012, 02:10 AM
  2. Off The Wall
    By msimpson99 in forum DIY CNC Router Table Machines
    Last Post: 05-31-2012, 05:31 AM
  3. air wall
    By Michael58 in forum GibbsCAM
    Last Post: 05-09-2011, 02:03 AM
  4. machining a horse and plow
    By woodman08 in forum Gorilla CNC Machines
    Last Post: 08-29-2008, 02:09 AM
