Quote Originally Posted by CaptainVee View Post
Thanks for the detailed pics, really nice to be able to follow this process closely!
You make it look easy
Could you share what mix you are using? It seems to be a mix of say 5 mm pebbles and sand and (estimate) 7%-10 or so epoxy?
Just re-iterating this request as I am very interested as well and didn't see a response from turpija. I would also like to know more information in general about the epoxy-granite mix you have used and the mix process. Did you use vibration or vacuum or maybe a chemical additive to de-aerate? The more information the better as your results look fantastic.
