Originally Posted by
kvadda
Hi, well i contacted machsupport, and they found nothing wrong with my g-code. I tried it myself on another computer, with paralell port settings, and it worked out ok.
Machsupport think it is something wrong with computer or external motion device. So i hooked up a laptop to the cnc, and used same settings, plugins etc, and got the same problem.
I attached the plugin here, dont know if anyone can see something wrong with it ?
Here is g code as well :
(BEGIN PREDATOR NC HEADER)
(MACH_FILE=3AXVMILL_MM.MCH)
(MTOOL T1 S1 D8. H127. DIAM_OFFSET 1 = 4.)
(MTOOL T2 S1 D5. H127. DIAM_OFFSET 2 = 2.5)
(MTOOL T3 S1 D10. H127. DIAM_OFFSET 3 = 5.)
(SBOX X0. Y0. Z-25.4 L900. W1620. H0.)
(END PREDATOR NC HEADER)
O100
(PROGRAM NUMBER)
(PROGRAM NAME - 1620H.NC)
(POST - MACH 3 MILL METRIC)
(DATE - FRI. 03/20/2015)
(TIME - 10:20PM)
N100 G21 G40 G49 G54 G80 G90 G91.1
N101 G0 Z0.
(JOB 1 HOLE RANDOM POINT PATTERN)
(8MMTAPPSTAMME)
N102 M06 T1
N103 S18000 M03
N104 G00 G90 G54 X857.5 Y107.
N105 G43 H1 Z2.54 M08
N106 G81 G98 X857.5 Y107. Z-17.403 R2.54 F3000.
N107 X793.5
N108 X473.5
N109 X409.5
N110 X153.5
N111 X89.5
N112 Y869.
N113 X153.5
N114 X409.5
N115 X473.5
N116 X793.5
N117 X857.5
G80G0Z0
M01 (You were missing some code here)
(JOB 2 HOLE RANDOM POINT PATTERN)
(8MMTAPPSTAMME)
N118 S18000
N119 G00 X857.5 Y1290.
N120 G81 G98 X857.5 Y1290. Z-21.403 R2.54 F3000.
N121 X793.5
N122 X633.5
N123 X569.5
N124 M09
N125 M05
N126G80 G0Z0. ( Need a G80 after each Canned Cycle )
N127 M01
(JOB 3 HOLE RANDOM POINT PATTERN)
(5MM STAMMEHULL)
N128 M06 T2
N129 S18000 M03
N130 G00 G90 G54 X839. Y520.
N131 G43 H2 Z2.54 M08
N132 G81 G98 X839. Y520. Z-15. R2.54 F3000.
N133 Y488.
N134 Y456.
N135 Y424.
N136 Y392.
N137 Y360.
N138 Y328.
N139 Y296.
N140 Y264.
N141 Y232.
N142 Y200.
N143 Y552.
N144 Y584.
N145 Y616.
N146 Y648.
N147 Y680.
N148 Y712.
N149 Y744.
N150 Y776.
N151 Y808.
N152 Y968.
N153 Y1000.
N154 X450. Y808.
N155 Y776.
N156 Y744.
N157 Y712.
N158 Y680.
N159 Y648.
N160 Y616.
N161 Y584.
N162 Y552.
N163 Y520.
N164 Y488.
N165 Y456.
N166 Y424.
N167 Y392.
N168 Y360.
N169 Y328.
N170 Y296.
N171 Y264.
N172 Y232.
N173 Y200.
N174 X47.
N175 Y232.
N176 Y264.
N177 Y296.
N178 Y328.
N179 Y360.
N180 Y392.
N181 Y424.
N182 Y456.
N183 Y488.
N184 Y520.
N185 Y552.
N186 Y584.
N187 Y616.
N188 Y648.
N189 Y680.
N190 Y712.
N191 Y744.
N192 Y776.
N193 Y808.
N194 X839. Y1448.
N195 Y1480.
N196 M09
N197 M05
N198G80 G0Z0. ( Changed Here also G80 Plus Z move)
N199 M01
(JOB 4 PROFILE)
(CUT 10)
N200 M06 T3
N201 S18000 M03
N202 G00 G90 G54 X905. Y-5.
N203 G43 H3 Z2.54 M08
N204 G00
N205 G01 Z-18. F3000.
N206 Y1630.584 F6000.
N207 X-5. Y882.362
N208 Y-5.
N209 X905.
N210 G80 ( A Bit late to add the G80 here it is of no use in this position )
N211 G00 Z2.54
N212 Z1.29
N213 G01 Z-19.25 F3000.
N214 Y1630.584 F6000.
N215 X-5. Y882.362
N216 Y-5.
N217 X905.
N218 G00 Z2.54
N219 M09
N220 M05
N221 G53 Z0.
N222 G53 Y0.
N223 M02
(END OF PROGRAM)
N224 M30
