588,055 active members*
5,210 visitors online*
Page 4 of 15 2345614
Results 61 to 80 of 286
  1. #61
    Feb 2015
    37
    Re: Chinese CNC Syntec 6MA my experience
    Quote Originally Posted by dunderdunder View Post
    Once again a great video! It´s logic and makes sense! What tool do you use for leveling your spoil board?
    Cheers
    Daniel
    Thanks Daniel, I use a 55mm balanced flycutter from Carbitool, it was about $200 USD, but it is balanced and the tips on the end you can rotate once they become worn, so you can get 4x the life out of it, and obviously they are replaceable at a fraction the cost of the original tool. Being that it is 55mm you can surface your spoilboard in no time at all
    http://s28.postimg.org/p9obg8ca5/Flycut_Tool.jpg
    Cheers
    Lee
  2. #62
    Nov 2009
    314
    Hi Lee,
    Would you mind to show me or Ellie the odd readings in the tool offset when you use auto tool calibration,we will ask our engineers to figure it out, more info/screenshot/video clip is appreciate !
    BTW,your demon video is great !
    Cheers,Mary
  3. #63
    Feb 2015
    37
    Quote Originally Posted by EXLASer View Post
    Hi Lee,
    Cheers,Mary
    Thanks Mary. but I am happy with the way my machine works and setting it up the way I did has it's advantages I'm not really interested in investigating the other method
    Cheers
    Lee
  4. #64
    Nov 2009
    314
    OK Lee,whenever you want this just let us know
    Cheers,Mary
  5. #65
    Feb 2014
    42
    Lee,
    Great fly cutter, looks awesome. See if I can get hold of one here in Sweden. I mill much foam and I think Cabitool cutter would work great on Styrofoam.
    Daniel
  6. #66
    Hello Daniel ,
    We are professional cnc router manufacture in China .We supply styrofoam machine .If you are intersted in it ,please add my skype anna.tian22 .
  7. #67
    hello ,
    We are professional cnc router manufacture in China .If you have any questions of woodworking machine ,welcome to contact with us .My skype is anna.tian22
    my whatsapp is +8613381182501
    thanks
    Anna
  8. #68
    Feb 2014
    42
    Hi Anna,
    I´m not looking for any machine, already got one machine.
    I´m looking for styrofoam cutting tools.
    Cheers
    Daniel
  9. #69
    Hi Daniel,
    It is ok .Thanks for your reply ! where are you from ?
    Best regards
    Anna
  10. #70
    Feb 2012
    87
    Hello,
    a question SolidCAM can use and create the g-code for syntec 6MA?
  11. #71
    Feb 2015
    37
    Quote Originally Posted by Peruanzon View Post
    Hello,
    I think almost all cad/cam programs create g-code, the questions is do you have a post processor that works with the Syntec 6MA in SolidCAM, if you don't have one I could look at modifying one for you if you can supply me with one of the existing post processors from the program. I have made post processors for both Vectric Aspire and Artcam that work with the Syntec 6MA ATC machines.
    Let me know if you would like help
    Cheers
    Lee
  12. #72
    Feb 2012
    87
    Thank you very much for your reply, although I have no machine but you need to know whether the SolidCAM software is fully compatible with Syntec 20AM.
    I think this is the most appropriate control system,i am looking for a machine to metal engraving
  13. #73
    Sep 2009
    1856
    ask on the solidcam forum if any one has a post for what you wont
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  14. #74
    Sep 2012
    228
    Hello Syntec Lee,
    Hello XYZ-TEch,
    Hello Others.
    I recently got a machine and started learning SYNTEC... LEE thank you for your videos...
    CAN ANYONE show me how to tech the machine where to pick up tools in the tool holder?
    I have a machine with an auto tool length touch off.. and a row of tools in the back... it's a linear tool holder setup...
    The machine only knows how to pick up tool 1 and 2... I need to tech machine how to learn correct position for tools 3 to 8...
    CAN ANYONE HELP?
    I also worked for 2 days going through many system settings and parameters... but some are hard to understand.
    I did adjust my rapids travel or cutting travel... but I don't see where you could teach the machine the tool positions.
    CAN ANY HELP with some ideas or Tips?
    Tank you in advance... the manual has terrible English... and Mach3s windows interface seems way more user friendly...
    Thank you for any help in advance..
  15. #75
    Sep 2012
    228
    Daniel,
    How is your experience with Syntec Going?...
    I just started to use it... or learn it for a few days.. and my linear ATC machine doesn't work correctly to pick up tools 3 to 8... only 1 & 2 work ok...
    Do you know how to teach the machine where the Auto Tool Sensor location is?...
    Do you know how to teach the machine where the individual tool holders are?..
    Are you happier now with the auto tool sensor functions?... using the 3811 parameter.. and external Z height seems to have some logic... Is it working out ok for you?
    Thanks for any input.
  16. #76
    Feb 2014
    42
    Hey Frank,
    I have no major problem with the Syntec controller and/or the tool sensor. Works similar to my Fanuc on the lathe. I use a different method of touching of the material than Lee but it works similar.
    Regarding the placement of the tools for the tool changer I found someone who explained how it should be done to get it to work here at CNCZone.com.
    BR Daniel
  17. #77
    Jun 2015
    109
    HI
    I have a new Syntec 6MD with Linear ATC, I am experiencing problems with the tool pick up. The Spindle doesn't always release and drags the tool through the tool support fork. I have looked at the operation carefully and it looks like the tool forks don't align with the home position position on X axis so I am considering adjusting this position which I presume is a parameter setting to adjust the travel after the X limit has been found.
    If anyone knows this parameter and more information I would be very grateful.
    P.S Is it me or is the manual very hard to understand?
    I have
    I am also looking for how to set some parameters for the tool change
  18. #78
    Feb 2014
    42
    Hello,
    I have adjusted all possible parameters in the Syntec system.
    Got the parameter somewhere and will get back with it.
    BR
    Daniel
  19. #79
    Feb 2014
    42
    Hello,
    Please see Brenek´s post. Might help.
    http://www.cnczone.com/forums/chines...e-3-print.html
    I fear I have to do this on my second machine (3-axis), on the 4-axis I have the same position for toolchange (rotary changer).
    BR
    Daniel
  20. #80
    Jun 2015
    109
    Hi
    Thanks for your help.
    I will wait and see what Omni (manufacturer) have to say tomorrow as the after sales guy wasn't there today. I've read the Brenek article. However it seem like a sledgehammer to crack a nut because all 8 tool holders are out by the same amount so surely if X home position can be adjusted then its the problem solved as far as miss alligment is concerned .
    There must be a parameter that adjust the x home position, its the one that tell the plc to move a certain increment distance forward then back after being sensed. My machine goes + direction by approx 25mm then - direction by approx 20mm. So I am wanting the "-" to be say 15 mm instead.
    Should be easy if only I had the parameter number
    Thanks anyway
    Will post the conclusion hopefully.
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Replies: 4
    Last Post: 10-29-2013, 02:23 PM
  3. Chinese Laser Software Experience?
    By Smiffy6885 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2013, 04:30 AM
  4. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 02:47 PM
