603,960 active members*
2,792 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers > How/Where to change Syntec interface from Chinese to English??"
Results 1 to 5 of 5
    May 2008
    Please, Any body know how to change parameter for changing the language to english
    Your help will be apreciated.
    thank in advance
    Mar 2010
    syntec
    please change parameter "3209" set 0 ,for changing the language to english
    password is 520
    Hi Mr. rvholiv,
    please how can i found the option to change the language 3209, because i wasnt found this option !!!
    so please can you help me ?
    Oct 2008
    16
    Omar, Press the following keys
    F6 - Parameters
    F5 - Go to
    a box will appear on the screen.
    Type in Parameter number 3209
    Select the value for english
    press enter
    password 520
    thanks for your replying , it's working
    please let me ask you how can i work with C Axis (rotation axis)
    so can you help me to know how to do rotation file ?
    and thanks again for you
  1. "Chinese" spindle minimum speed
    By Hirudin in forum Spindles / VFD
    Last Post: 12-21-2019, 01:47 PM
  2. Buying Chinese 1200x1200 (48"x48")
    By rosco in forum Chinese Machines
    Last Post: 08-21-2010, 11:06 PM
  3. "Runtime error 9 - subscript out of range" on Techno CNC interface
    By zhoudfoster in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-26-2009, 04:57 AM
  4. Replies: 6
    Last Post: 01-26-2009, 03:53 PM
  5. how do i change pcnc software to english from german
    By chris69randy in forum DIY CNC Router Table Machines
    Last Post: 05-24-2005, 08:35 PM
