588,344 active members*
5,024 visitors online*
Results 1 to 2 of 2
    Oct 2008
    23
    Changing drive gears
    I have an '03 era Multicam M series 4'x8' table, the x and y axis gears need to be replaced due to wear, I called my Multicam distributor and they said that part doesn't exist any more but they think they have a replacement for it, turns out to be the wrong size, 40 tooth instead of 25 tooth, my question is can I change out the different sized gears and then change the parameters in the driver settings? MC couldn't answer that question. Any help is much appreciated!
    Jun 2010
    463
    Re: Changing drive gears
    Give me a call I might be able to help....have the dimension of the gear spur for me.
    Maurice 678-548-1483
    MCP Services.
  1. Changing the drive belt.
    By Denis Vallières in forum Daewoo/Doosan
    Last Post: 10-06-2014, 09:26 PM
  2. how to remove backlash in knee drive bevel gears
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 04-26-2012, 08:47 PM
  3. changing gears low to high M41-M43
    By valleymach in forum Daewoo/Doosan
    Last Post: 05-15-2010, 03:04 PM
  4. Changing the main drive belt on the spindle
    By Michael82 in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2009, 03:09 PM
  5. Changing the drive v-belt
    By ken65 in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2006, 04:36 PM
