Originally Posted by
bloke
When you Fdisk and format the HDD, it sets it up as the BIOS is programmed. You may find that you have the EPROMs on the CPU that are programmed with the fixed HDD and memory. If so, you won't be able to alter the BIOS without the later EPROMs.
Fdisk it with a 10Mb active partition.
Fdisk the remainder as the second partition.
Format C:\ and give it a volume name of EXECUTIVE_1
Format D:\ and give it a volume name of PART_PROGS
Make sure the first file loaded from the executive disks to C:\ is HURCO.LDR
Copy the remaining files from the floppies to the C:\ drive
Combine EXECUTIVE.001 and EXECUTIVE.002
Run the bootloader
Add the configuration files from the config. floppy to the same locations on the C:\ as they were on the A:\
