588,076 active members*
4,784 visitors online*
Thread: Hoss's G0704
Page 318 of 344 218268308316317318319320328
Results 6,341 to 6,360 of 6871
  1. #6341
    Oct 2014
    30
    Re: Hoss's G0704
    Hoss, glad to see you post, because I am lost.
    I had been using your probing screen set, but had to change computers for my X2 setup. When I reinstalled Mach3, I still had all the zip files from installing your screen sets, but ran into a problem.
    I had an installation problem the first time I set it up, but found your easy, clear directions in a forum thread. Now I can't find that thread and can't get the screen set to load all the buttons and bitmaps.
    Can you point me to the thread where you talked about installing the screen sets? I saw your video, a couple times, but it didn't seem to do the trick.
    Appreciate your help and all you do for us here.
    nvm, figured it out all by myself!
  2. #6342
    Dec 2005
    8
    Re: Hoss's G0704
    Just getting around to the Hoss Phase 2 C7 ball screw conversion and would like to know the difference between the "angled" Y axis ball nut mount and the "regular" Y axis mount ( non-Angled ) ?
    Happy Turkey day to all !
    Jake
  3. #6343
    Re: Hoss's G0704
    The "angled" one positions the oil port at the top which is beneficial for use with an oiling system otherwise the normal one keeps the ballnut in it's common position with the port at the side.
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
  4. #6344
    Jan 2011
    43
    Re: Hoss's G0704
    Hoss, I am so glad to see that you are still doling out free advice on CNC builds. Whenever I find myself in a build bind I just mutter out "WWHD?". Have a happy Thanksgiving!
  5. #6345
    Re: Hoss's G0704
    Thanks and a happy turkey day to you too!
    Hoss
Name:	happy thanksgiving.jpg
  6. #6346
    Nov 2013
    143
    Re: Hoss's G0704
    Hey Hoss, quick question...
    I purchased the VBX bearings listed on your website (7007B and 7005B)
    I am trying to figure out which way these things are supposed to be installed. Was watching your video on bearing replacement, but the bearings in the video are slightly different, so I don't want to make any mistakes.
    Do you have any info on which way these are to be installed?
  7. #6347
    Sep 2009
    1856
    Re: Hoss's G0704
    Quote Originally Posted by Poseidon View Post
    I like that WWHD I am the same look at hoss's post when I am stuck on something or youtube vid's
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  8. #6348
    Re: Hoss's G0704
    Quote Originally Posted by Semus View Post
    You'll notice the outer race on one side of the bearing is thicker than the other side.
    They install so they face each other when installed.
    The thicker side faces up on the lower bearing and the thicker side faces down on the upper bearing.
    Hoss
  9. #6349
    Oct 2009
    483
    Re: Hoss's G0704
    Hello Hoss,
    Glad to see you're still around. The thread has been too quiet lately.
    There is a big Enco sale ending at 11 PM Eastern tonight (just over 90 minutes from now). 25% off everything AND Free UPS Ground shipping. No minimums.
    I have two different sets of codes. One set is "SPECIAL" and "OFFER" and excludes machinery. The other is "CYBER" and "MONDAY" and has no exclusions. The first code is for the 25% off and the second is for the free UPS shipping.
    So there are a bunch of goodies I've had my eye on, but I realized that I have very few quality end mills. What size and type of end mill would you recommend stocking up on for one of the smaller Novakon CNC mills (just a tad bigger than the Tormach 770)? I also have a G0704. The only end mills I currently have are the ubiquitous set of 20 yellow end mills (10 different sizes in both two and four flute) from China, and a couple of long reach carbide tools used for 80% lowers.
    Thanks!
  10. #6350
    Re: Hoss's G0704
    I always have a good supply of 1/4 and 3/8 2fl endmills on hand for most machining, Hertel is a good brand.
    Hoss
  11. #6351
    Oct 2009
    483
    Re: Hoss's G0704
    Hoss,
    Thanks for the reply. Are you using the 2 flute for both aluminum and steel?
    I see Encol has Hertel HSS double end mills and M-42 cobalt ball end mills in the Hot Deals catalog.
  12. #6352
    Re: Hoss's G0704
    yes i do.
    Hoss
  13. #6353
    Nov 2015
    24
    Re: Hoss's G0704
    Quote Originally Posted by Titaniumboy View Post
    Hello Hoss,
    Thanks!
    That's good coupon code. I put one of their Enco brand Mills in the cart Item Model #405-0593, and price went from $2355 to $1766. However, I already decided on a G0704, so I'll probably let it go. Seems like a good deal, I just am not familiar with their products.
  14. #6354
    Oct 2009
    483
    Re: Hoss's G0704
    Hoss, thanks for the cutter advice. I ended up getting two each of a Hertel 1/4" HSS double-ended and a Hertel 3/8" HSS double-ended end mill. Cost was $7.46 +tax delivered for each end mill.
    The Enco sale was extended until 8 PM Eastern tonight, so there is 3-1/4 hours to take advantage.
  15. #6355
    Nov 2015
    24
    Re: Hoss's G0704
    Quote Originally Posted by hoss2006 View Post
    If you plan to run Mach 3 they have some basic requirements.
    Mach3 Minimum Requirements:
    32-bit Desktop (using the parallel port)
    32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 Operating System (64-bit will not work)
    1Ghz CPU
    512MB RAM
    Non-integrated Video Card with 32MB RAM
    Basic Computer Skills (ability to copy/rename files, browse directories, etc)
    Laptop / 64-bit Desktop (using an external motion controller)
    An appropriate external motion controller (options can be found on the Plugins page)
    1Ghz CPU
    512MB RAM
    Best to get a desktop that comes with a parallel port already, I'd get a 2Ghz which are pretty cheap these days.
    Check pricewatch.com.
    Hoss
    Want to apass on I found a good resource for older desktop computers - Goodwill. The guy at Goodwill told me they wipe the hard drive of all donor machines and do a clean install of Windows 7 Pro. The install is through some partnership with Dell. I purchased a Pentium Dual Core PC, with 2 GB ram and 160 GB harddrive (no monitor, I already had one) for $70. It runs real well. Has a Windows 7 rescue disc included.
    Questions:
    1. Once I get Mach 3 installed, how often will I need internet - I have no internet in the shop.
    2. Is there any other reason anyone can think of as to why I'd need internet to run Mach 3.
  16. #6356
    Re: Hoss's G0704
    You won't need internet at all to run Mach 3, many purposely keep their Mach 3 pc disconnected from the internet since it has caused some problems, never bothered my machine though.
    Hoss
  17. #6357
    Nov 2015
    24
    Re: Hoss's G0704
    I purchased the Kit from Automation Technologies that included items listed below. I assume the 5V power supply is to run the Breakout board?? If so, I'm confused as the power supply is a 'plug', but the area on the breakout board appears to just accept bare wires............Am I missing something??
    NEMA23 4-Axis CNC Kit with KL-5056 Bipolar Driver, 48V/12.5A Power Supply (110V/220VAC)
    (4) 570 oz-in stepping motors, NEMA23, KL23H2100-50-4B (3/8” Dual shaft with a flat)
    (4) KL-5056D Digital Stepper Drivers (5.6Amp 24-50 Volts, 1-1/256 microstep driver)
    (1) KL-600-48: 48VDC /12 .5A Power Supply 110VAC/220VAC ( Black one)
    (1) C10 Breakout board ( You can wire E-Stop, limit Switch, etc)
    (1) 5V power supply
  18. #6358
    Re: Hoss's G0704
    Cut and strip the wires to attach to the breakout board.
    I always tin the end of my wires too.
    Hoss
  19. #6359
    Jan 2015
    12
    Re: Hoss's G0704
    Hoss, what is your opinion of using limit switches for homing? I'm defiantly going to install some for use as limit switches. I was looking at these and these on fleabay.
  20. #6360
    Nov 2015
    24
    Re: Hoss's G0704
    Am surprised you need a double female parallel cable to connect computer to breakout board. Those are a little difficult to find these days.
  1. Hoss's G0704
    By hoss2006 in forum Benchtop Machines
    Last Post: 03-25-2016, 12:48 AM
  2. Another G0704 conversion - Hoss's plans - LinuxCNC control
    By otto_pjm in forum Benchtop Machines
    Last Post: 11-14-2013, 06:26 PM
  3. G0704 Y axis Thrust Bearing Block and Stepper mount from Hoss Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 12-12-2012, 02:49 AM
  4. RFQ A few parts from Hoss G0704 Plans
    Last Post: 10-21-2011, 09:13 PM
  5. Hoss does it again!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 11-01-2008, 06:29 AM
