Thats probably a good idea. I will order some r8 collets to try mounting the tooling directly in the spindle. Actually the tool stick out is less than what I need. I need 35mm since that is the material thickness, It is 32mm.
The material is a common construction steel around 150-190 HB.
Equal to:
S355J2G3 / S355J2G3+N
EN 10025-2 : 2004
ASTM E290-97a
NACE MR-0175 / ISO 15156
AISI A 350 LF2
