I'm milling a single, straight line whose coordinates go from (on the y axis) at 0.4 to -2.5.
I'm having trouble telling BobCAD which direction the CAM toolpath is generated in. Sometimes it starts at the 0.4, sometimes it starts at the -2.5. This is using the profile function on a single, straight line.
I thought it might be "reverse" contours or show surface normals, but neither of those seem to do the trick. I want to be able to telling BobCAD which direction it should mill the line in!
Thoughts? Thanks.
