587,651 active members*
3,665 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > What happens to the air sat in the mould?
Results 1 to 9 of 9
    Scooby Guest
    When injection moulding what happens to the air in the mould?
    The moulds ive seen have gates, spruce and runners but i dont see anywhere for the air in the mould to escape, will this not give defects in the mould? obviously it doesnt so im interested what allowance i need to make for it, obviously a hot shot traveling down a long thin part will get quite some build up at the bottom the more plastic is pushed in.
    15362
    Hi Scooby
    If you look very close at the the faces of the mold/mould you will see ground vents these are ground to different depths depending on the material being used, Material will flash out the vents if they are to deep this is one way.
    These vents start at around .0005" deep
    The ejector pins in the back of the mold/mould also can have a ground flat on them all most to the end of the pin (Like .100" from the end ) the pin has a small clearance in its hole as well (Like .0005" ) this lets the air/gas out of the mold/mould The clearence the ejector pin has also is to do with what material you are using some materials flash easyer than others so you have your clearence to suit the material you are using
    They also can add vaccum to the closed mold to evacuate the mold this is the way to evacuate a mold of air/gas on hard to Fill cavitys
    There are also small valves that can be made that are open before the shot is pushed in & close as the pressure builds up in the mold/mould
    Mactec54
    Jun 2007
    3735
    Lightbulb Burn marks.
    Sometimes trapped air becomes obvious as burn marks in the plastic.
    Scooby Guest
    Thankyou both for your replies, most helpful. I didnt realise the plastic burns where there may have been a trapped air pocket, thats good to know to look for.
    Mar 2006
    61
    heat generated by escaping air
    I once made a large Aluminium mould for a 4ft long frame the air escaping from the corners produced so much heat escaping, the aluminium melted at the corners which had to be replaced with steel inserts
    15362
    Hi Stu M3
    If your mold/ mould had good vents this would not of happened
    Mactec54
    Jun 2015
    20
    Re: heat generated by escaping air
    Quote Originally Posted by Stu_M3 View Post
    we also meet this problem
    Jun 2015
    20
    Re: What happens to the air sat in the mould?
    Quote Originally Posted by Scooby View Post
    have you solve this problem? if not, can send me 3D , I can give you solution way.
    Jun 2015
    20
    Hi Scooby
    learn a lot, thanks
  1. RTV gasket mould
    By cimbian in forum CNC Tooling
    Last Post: 12-13-2013, 09:02 PM
  2. Rapid mould
    By clachan in forum Moldmaking
    Last Post: 11-19-2008, 11:00 PM
  3. aluminum mould required
    By SNOOPER666999 in forum Hobby Discussion
    Last Post: 02-11-2007, 08:18 PM
  4. Material for mould
    By CarbonMike in forum Glass, Plastic and Stone
    Last Post: 11-07-2005, 08:06 PM
  5. Sanding a mould
    By MBG in forum Moldmaking
    Last Post: 09-26-2005, 06:45 PM
