We have an Amada Pega357 with Fanuc 04PC control and We have error msg.:
" E 44 HDLC response time out - error "
Can Anny help?
Can Anny help?
I get this on start up:
"bootstrap file A: cannot find loader"
"bootstrap file B: cannot find loader"
"bootstrap file C: cannot find loader"
"bootstrap file D: cannot find loader"
"bootstrap file E: cannot find loader"
"bootstrap file F: cannot find loader"
"bootstrap file l: cannot find loader"
Press "MMC/CNC" button.
What happens?
Press the Message key to see what alarm is displayed. Could be a servo alarm, something wrong with MMC circuit, or a problem with Emergency Stop releasing.
Where should be connected this end of cable,
Attachment 314476
Other end is connected here:
Attachment 314478
Other pictures:
Attachment 314480
Attachment 314482
Attachment 314484
I cannot view those attachments. Can you try to load them again?
Thank you.
hi Jovanov,
did the machine went into power down situation ?? by any chance...?
it looks like your FANUC boot loaders are not loading properly. Check the I/O board connections.
By the way the attachments are not opening. pls Re-post them.
thanks.
Attachment 314508
Attachment 314510
Second picture is A16B-1211-0900-13B, connector is M24
M24 should go to M60 on a IO board
Thanks,
"bootstrap drive A: cannot find loader"
"bootstrap drive B: cannot find loader"
"bootstrap drive C: cannot find loader"
"bootstrap drive D: cannot find loader"
"bootstrap drive E: cannot find loader"
"bootstrap drive F: cannot find loader"
"bootstrap drive l: Loading CCPM.SYS
This is video of start up:
https://youtu.be/cGqjGtWyKW4
That's a good step. Has this machine been off for a while? Push the MMC button again. Same NOT READY screen? It just booted up on the MMC side. There is a parameter to switch which side is booted on startup.
13 bit 4
0=CNC screen
1= MMC screen
As i said your machine is not booting properly. Do you have Parameter & DGN backup...?
if so try flushing the parameters .
Yes, it was off for a while, I push the MMC button again, Same NOT READY screen... How to change parameters?
No, I dont have Parameter & DGN backup...
On which PCB is stored drive A:, B: C: D: E: F: ? - On memory board, or other?
HI
at least do you have the parameter tapes ( perforated black tapes) with you ? ( usually supplied along with the machine )
if not then it will be little difficult to restore the machine on your own.
was this machine working OK with you before ?
If at all you need I can make a visit to the place to restore your machine.
let me know. Contact me at [email protected]
