588,350 active members*
5,850 visitors online*
Page 8 of 15 678910
Results 141 to 160 of 286
  1. #141
    Aug 2009
    655
    Re: Chinese CNC Syntec 6MA my experience
    Switch. On the pc side where is the shared folder located? Mine is in /users/public/cnc (windows 10).
    Sent from my LG-D852 using Tapatalk
    In case anyone is wondering, I'm the twin of the other gfacer on cnczone...
  2. #142
    Aug 2009
    655
  3. #143
    Dec 2010
    70
    thanks a lot for involving
    for now, I give up
    I'll take another computer with a clean W7 on it
    it seems this W10 is messed up and I cannot spend more time with it
    again, many thanks
    I'll post results after I'll try this with the W7 computer
    regards,
    Seb
    HTM.Ro - Hobby Tools Manufacturing
  4. #144
    Dec 2010
    70
    SOLVED!
    the issue was generated by norton's f***** smart firewall
    now I have to figure out how to resolve the other machine's problem: squaring the gantry
    the way I like is to add a home switch to the slave axis
    easy to say... will see... hope I'll found the solution somehow
    regards,
    Seb
  5. #145
    Aug 2009
    655
    Easy to say is right, then you would have to program that into the syntec. Yikes... I'd try to loosen the gantry and square and retighten first. If you do do it in Syntec be sure to post about how.
  6. #146
    Dec 2010
    70
    yes, this could be a solution but you have to do it daily and I don't like it
    I have custom made machines with master/slave independent homing even for Y and Z axis, driven by a simple Mach3 without problems
    I presume the Syntec controller can do the same thing but until I find how to do this, without documentation... just hope I'll do it before my retirement... I'm just 44...
  7. #147
    Aug 2009
    655
    Hey guys, any chance I could get a few screen shots of your servo tuning screen (parameters screen the arrow right) if you have yaskawa sigma 7s. I'm trying to see if some fiddling will help me get better cuts on circles. It would help to see what settings other factories might have used. Thanks .
  8. #148
    Feb 2014
    42
    gfacer the second, if you get any result please publish! My circles suck to!
  9. #149
    Dec 2010
    70
    My machine have 5s, not 7s. Will help?
    If yes, let me know where can I find the servo tuning screen
  10. #150
    Aug 2009
    655
    Quote Originally Posted by interzis View Post
    It might
    So servo tuning should be an option if you go to parameters (ie hit the parameters button) then right arrow and you should get to a screen that has servo tuning button at the bottom. Then I think only one option will be highlighted (for sigma 5).
    The parameters will read P at the beginning. Thanks, Graham
  11. #151
    Dec 2010
    70
    It seems I don't see that screen...
    No other options available
    mobile...
  12. #152
    Aug 2009
    655
    Do you get it if you hit the right arrow to the right of F5 at that screen?
  13. #153
    Dec 2010
    70
    No, the right arrow is useless in that pictured screen, it does not show any other option
  14. #154
    Aug 2009
    655
    Hmm interesting. Oh well, worth a shot. I know the 6md and the 6ma controls are slightly different and one of them was a serial connection with the servo (if I recall).
  15. #155
    Apr 2016
    3
    I use Artcam, they can tell me postprocessor be used to syntec? please!
  16. #156
    Aug 2009
    655
    Quote Originally Posted by razhoffman View Post
    What type of router do have (tool change or single head or multiple head)
  17. #157
    Apr 2016
    3
    Quote Originally Posted by gfacer2 View Post
    Is a tool chage with 6 tools
  18. #158
    Aug 2009
    655
    Linear or rotary?
  19. #159
    Apr 2016
    3
    Linear or rotary?
    Linear
  20. #160
    May 2016
    Hi Lee,
    I have seen your video on you tube and they have been pretty helpful to a complete rookie of 2 weeks. I got a ATC3015 with syntec controller. I have marched on and after a few hurdles got it cutting. But have a few problems well three at the moment. Yesterday it was cutting fine. But the hood for the tool was catching i took the covers off and back on. Went to run a new program and got the two errors bellow.
    1.
    Motion 17 Z axis first positive software limit exceeded
    When i run a program this warning comes up but the machine will not have moved. When press run cycyle and before it moves any axis the warning comes up.
    If i move the z axis (in jog) the error goes away but if i try run the program its back and the z would have gone no where. but i can home all the axis fine so it goes to the Z limit and no problem. But i run a program and it halts everything
    Coordinate 40 the1NcporgramL7: Block end point exceed software limit
    This i have no idea what is going on.
    One minute its working then i load a new file and nothing.
    I try other files ( that were working fine) and nothing
    I have turned off and on, home the axis and all is good, run file then the two errors come on.
    I Have deleted the new file and almost all files from the computer, turned off/on and tried a file that did work fine yesterday, still the two errors pop up.
    I was only about to start some real work on it after 2/3 weeks of just getting it to cut and now i'm standing looking at the machine about to lose my mind.
    On another point i have only been b=manually changing the tools as the when i tell it in V carve to use T2 or T3 when i export it to machine it always says T1. But that's a whole other thing. if i could just get it cutting with T1 for now i'd be more than happy.
    any help gratefully appreciated,
    James
    where abouts in NZ are you?
Page 8 of 15 678910
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Replies: 4
    Last Post: 10-29-2013, 02:23 PM
  3. Chinese Laser Software Experience?
    By Smiffy6885 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-18-2013, 04:30 AM
  4. Who has syntec controller running there chinese atc
    By simso in forum Chinese Machines
    Last Post: 10-22-2011, 02:47 PM
