603,796 active members*
4,830 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > "R less than z in cycle in xy plane" and I have no clue
Results 1 to 12 of 12
    Feb 2004
    1311
    Re: "R less than z in cycle in xy plane" and I have no clue
    I went back and re-did the part in BobCAD as I suspected it might have something to do with inexperience since this was one of the first parts I experimented with but never actually cut. This time it seems to work, I haven't cut yet but I ran in a local simulation copy of Mach and it didn't balk. Unfortunately, I don't have the old version so I think I'll just move on and call it "experience".
    I did run into an odd thing though - the 1/2" hole on the left edge of the part is roughed as a pocket with a finish profile pass. I used the Spiral option for material entry with the default .25" radius. Even with simulation I did not notice that the roughing was actually cutting a much larger pocket offset from the center. So I ended up with a much larger hole that is offset. I would have expected BobCAM to report that the cut was going outside the boundary. Now I know to pay close attention to these things.
    I use this hole as my datum and probe to find its center. I have a couple of options to fix this. I'm leaning towards milling a larger .9" hole offset so the incorrect hole is completely removed. The only reason I need to do this is because the finish pass took a little crescent out of the right side of the pocket so it is not perfectly round along X. In practice this should not cause a problem since I could still probe the middle and all of the hold down locations will be bored after probing. But I'm a bit of a perfectionist so I think I'll overbore the hole and adjust my part offset by .1" (which is what I determined by measuring) and go from there.
    Reelsmith, Angling Historian, and Author of "The Reelsmith's Primer"
    www.EclecticAngler.com | www.ReelLinesPress.com
    Jun 2008
    1838
    Quote Originally Posted by mhackney View Post
    Hmmm, as you haven`t uploaded a file or images no idea really what you are talking about
    Usually if you are going outside a hole with a spiral entry the spiral radius is too large
    Only think I can think of with the drilling cycle is that on the machine you will have set a Part Zero, if that isn`t set to Z0.00 then you could have a problem I assume testing on your desktop you haven`t set that ? ?
  1. Replies: 1
    Last Post: 09-18-2014, 09:57 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. want to buy cnc "haven't got a clue"
    By bob b in forum Want To Buy...Need help!
    Last Post: 12-06-2010, 12:55 AM
  4. "jword given for arc in xz plane line number xxx" ???
    By HankMcSpank in forum G-Code Programing
    Last Post: 05-11-2009, 01:28 PM
  5. "Bug Plane" ?????? error??
    By shnitzel in forum Mach Software (ArtSoft software)
    Last Post: 10-06-2007, 04:53 AM
