588,152 active members*
4,702 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Huanyang Chinese VFD settings and manual here!
Page 8 of 41 67891018
Results 141 to 160 of 808
  1. #141
    15362
    Re: Huanyang Chinese VFD settings and manual here!
    keiner99
    You need a relay to switch the DCM and Forward top row of the VFD above where you have the 0-10v, you need to set PD044=01
    so an output from Mach 3 that turns the Relay on for M3 and off for M5
    Fix your Ground wire connection, these are important, also check the pin 4 at the spindle for Ground, continuity between Pin 4 and the spindle body, this is very important, most have to be modified
    This is how you would do it without the reverse
    Mactec54
  2. #142
    Jun 2016
    9
    Hello!
    I'm not sure if i have understand you right. Attached you will find a picture - am I right?
  3. #143
    15362
    Quote Originally Posted by keiner99 View Post
    Hello!
    Yes that is correct, but check the DCM on the top Terminal row is the same as the bottom row DCM, it should be, what you can do to check is to just use a jumper wire, between the FOR and the DCM this should start your spindle if all your settings are correct, you can not run it like this, only test
    If it does not start with this, then there may be a jumper that you need to change Do the PD044 setting try this first, is the 0-10v output working, have you checked it's output to see if the voltage changes as you change the speed in Mach3
    Mactec54
  4. #144
    Jun 2016
    9
    Hello!
    I have connected the VFD like on the attachment.
    The 0-10V output from my breakout board is working. PD001=1, PD044=01. When I start the VFD is run up to 24000 rpm, even it get 3V from the 0-10V cable. What is wrong?
    EDIT: I have tested both DCM ports - the problem is the same
    Franz
  5. #145
    Jul 2014
    10
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  6. #146
    15362
    Hello!
    Franz
    You can't just try each DCM ports you have to check with a meter with the power off, this is very unusual that there are ( 2 ) DCM ports, and I suspect, it is either labeled wrong or that you may have a VFD that is a copy, a poor copy of the real thing
    looking from the front,to the right side of the terminal block you will see J1 this is a jumper that may need changing, move the jumper to VI
    It will look similar to this photo
    Mactec54
  7. #147
    Jun 2016
    9
    Hello!
    I have already made an circuit continuity test and it has continuity. so I think the DCM ports are the same... the J1 jumper was already on VI... any other suggestions?
    Franz
  8. #148
    15362
    Hello!
    Franz
    That is correct if they have continuity either could be used, strange the jumper was already set, as this disables the keyboard when set on V1, this may be backwards, but try the PD044 change first
    Try PD044=02
    Mactec54
  9. #149
    Jun 2016
    9
    PD044=02 --> same problem
  10. #150
    15362
    Are these 2 connections correct VI has the 0-10v and the common to ACM are correct, with these ( 2 ) wires disconnected, connect them to you meter does the voltage change when you change the speed command from Mach3
    Mactec54
  11. #151
    15362
    keiner99
    I see you did not set these Parameters in your Parameter list, you need these set
    PD70=0 ( This may need to be set to 1 for normal use )
    PD72=400
    PD73=120
    Mactec54
  12. #152
    Jun 2016
    9
    Hello!
    Now I have also set PD44=1, PD70=0, PD72=400 and PD73=120. Same problem.
    The 0-10V signal was on VI and ground on ACM. I have made two pictures with 10000rpm and 20000rpm ( set on mach3).There you can see, that the voltage changes (Y)
  13. #153
    15362
    Hello!
    That all looks good
    Try this Parameter PD002=1
    Mactec54
  14. #154
    Jun 2016
    9
    you are a hero - it works
    but i have another small problem: When I say 24000rpm in mach 3 i get 23900rpm on the inverter, but when I reduce the rpm in mach3 the difference get bigger and bigger:
    on mach3 | on the inverter
    24000rpm - 23910rpm
    20000rpm- 20470rpm
    16000rpm- 17220rpm
    12000rpm-14340rpm
    10000rpm-12960rpm
    8000rpm-11700rpm
    Where can i calibrate it?
  15. #155
    15362
    24000rpm - 23910rpm
    20000rpm- 20470rpm
    16000rpm- 17220rpm
    12000rpm-14340rpm
    10000rpm-12960rpm
    8000rpm-11700rpm
    So did you have PD044 set to 01 or 02, or do both work
    Calibrate, this can be hit and miss with Mach3 under motor tuning you can play with the spindle settings,
    Under Config you have Pulley selection
    Under Ports & Pins you have spindle setup motor control
    Some PWM controls also have a Trimpot to adjust the Voltage
    So lots to play with, but will mostly be to do in the spindle setup adjusting the Frequency, if the other pulley settings Etc are correct
    Mactec54
  16. #156
    Jun 2016
    9
    ok thank you very much
    PD44 01 or 02 work both... which would you take?
  17. #157
    15362
    02 is the Drive default,so that is why I don't have it in my Parameter list, it's just one parameter that normally is not needed to be changed
    There is another Parameter that can affect the speed so if all else fails you can play with this parameter
    PD071 default it is set at 20 it has a range of 0-50 with can change how the speed is controlled, only go there after the mach 3 settings have been setup
    Mactec54
  18. #158
    Jun 2015
    10
    Hi all,
    I have bought myself the Routakit SDX machine everything is built I am just stuck on the Huanyang VFD. I also have the 1.5 spindle
    the parameters that I have set for the VFD are as follows.
    PD013 - 8
    PD001 - 0
    PD002 - 1
    PD004 - 400
    PD005 - 400
    PD006 - 2.5
    PD007 - 0.5
    PD008 - 220
    PD009 - 15
    PD010 - 8
    PD011 - 120
    PD014 - 5
    PD015 - 5
    PD023 - 0
    PD025 - 1
    PD041 - 8
    PD072 - 400
    PD073 - 120
    PD141 - 220
    PD142 - 7
    PD143 - 2
    PD144 - 3000
    and in that order if that matters :?: I have seen some people believe the order you do matters but others say different.
    The spindle runs BONUS!! no overheating . but I have come across one issue. I have the control knob on the VFD. start spindle on slow with the knob turned left as I turn the knob fully right to achieve maximum RPM(24000) it stays on 15600ish. does anyone know why this is??
    Thanks in advance
    ACE8421
  19. #159
    15362
    Quote Originally Posted by Ace8421 View Post
    Hi all,
    PD013 - 8
    PD001 - 0
    PD002 - 1
    PD004 - 400
    PD005 - 400
    PD006 - 2.5
    PD007 - 0.5
    PD008 - 220
    PD009 - 15
    PD010 - 8
    PD011 - 120
    PD014 - 5
    PD015 - 5
    PD023 - 0
    PD025 - 1
    PD041 - 8
    PD072 - 400
    PD073 - 120
    PD141 - 220
    PD142 - 7
    PD143 - 2
    PD144 - 3000
    Thanks in advance
    ACE8421
    It does not matter what order or how you set the Parameters, as long as they do get set correctly
    You are missing a critical Parameter, and will damage your spindle, I'm not sure why people can't follow the parameters I post, the list I did has been around everywhere for the last 5 years
    PD003=400 this must be set this is one of the critical Parameters and you don't have it in your list, a guess you have left it at the Default of 0/50hz, if this Parameter is left at the 0/50Hz it will damage your Spindle
    PD002=0 this needs to be Zero if using the keyboard control, only if you use remote control you change it to ( 1 )
    You have added 2 other Parameters which should be left as Default
    PD023=0
    PD025=0
    If they are not in list of Parameters to change then you should not mess with any other parameters, unless you are an expert VFD control programer
    Mactec54
  20. #160
    Jun 2015
    10
    Hi mactec54
    I have got the variable speed control on the VFD so I have left the PD002 as is but the others I have changed and still having no luck. turn the knob fully right and it still only reaches 15600 RPM??
    Would I just be better of resetting the VFD with PD013 -8 and going through it all again?
    kind regards
    Ace8421
  1. Replies: 6
    Last Post: 05-04-2024, 04:05 PM
  2. Car hoist 3phase settings on huanyang vfd
    By pietskiet in forum Spindles / VFD
    Last Post: 10-21-2019, 10:04 AM
  3. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  4. Huanyang inverter PD settings
    By jamriggsy in forum Phase Converters
    Last Post: 03-15-2013, 04:54 PM
  5. Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    By EmeraldIsleforg in forum Phase Converters
    Last Post: 09-23-2012, 03:00 PM
