587,933 active members*
3,756 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Amada pega fanuc 04pc system error
Page 2 of 3 123
Results 21 to 40 of 43
  1. #21
    Oct 2005
    89
    Re: Amada pega fanuc 04pc system error
    Hi Ajay,
    Assuming your controller is 04PC ......check adjust the X axis Grid shift Parameter No. 82 ......
    the value of this parameter can be positive or negative ......... ( Note the initial value ) and change as per your requirement.
    **** we provide all kind of Troubleshooting & Maintenance Services for CNC Turrets , Lasers & Press Brakes. Let me know if needed......!
    Get in touch on [email protected] ( 9404222266 / 8554014614 )
    thanks.
  2. #22
    May 2016
    14
    Thanks Mr. Pitre,
    Will check and revert in a day. BTW what is your location in India, I am at 200 KM from Delhi, in Haryana.
    Thanks a lot for your help.
    Regards,
    Ajay
  3. #23
    Oct 2005
    89
    Hi Ajay,
    I am based in GOA .....25 kms.....from the capital Panaji......
  4. #24
    May 2016
    14
    Thanks a lot Mr. Pitre,
    The machine is working fine now, but some time we are facing a problem... the holding down clamps will not come down to hold the sheet while repositioning and alarm 2042 W Dog Timer (M10-01ExEcMF TF-EF) appears on the controller.
    Can you please guide?
    Ajay
  5. #25
    Oct 2012
    40
    Mr. Ajay
    This is Deepak from mumbai.
    I just want to know that you are talking about clamps or work holder? if you are talking about work holder then you have to check the valve or clean the cylinder.
    You can call me :- +91 9222018538 / +91 8149636586
    we dealing in all kind of Troubleshooting & Maintenance Services, Retrofitting, Installation for CNC TPP, Lasers, HMC, VMC, VTL Etc. Let me know if needed......!
    Get in touch on [email protected] / [email protected]
    Thanks & Regard's
    Deepak
  6. #26
    May 2016
    14
    Hello Mr. Deepak
    Thanks for your support, will get the valve clean today and let you know the outcome.
    Sure, will get in touch if I need your help.
    Thanks,
    Ajay
  7. #27
    Jan 2011
    13
    My Amada machines lost all parameters because of long electric failure and the batteries did not hold.
    When the power was restored the Amada machines already had lost everything.
    Amada Apelio II 357 05PLA( Combi machine Laser Punch )
    Amada Pega 244 04PC ( Punch Machine )
    Do you have backup parameters for this machines if possible also the MMC parameters.
  8. #28
    May 2016
    14
    Quote Originally Posted by Barbwier View Post
    My Amada machines lost all parameters because of long electric failure and the batteries did not hold.When the power was restored the Amada machines already had lost everything.Amada Apelio II 357 05PLA( Combi machine Laser Punch )Amada Pega 244 04PC ( Punch Machine )Do you have backup parameters for this machines if possible also the MMC parameters.
    I am sorry for replying late, but my machine is Pega 344. Will it help?
  9. #29
    Oct 2005
    89
    hi...
    I shall be re-installing one Apelio machine after couple of weeks....I can help you at that time.
    you will have to wait till then.
  10. #30
    Mar 2009
    101
    Quote Originally Posted by Pitre View Post
    hi...
    I sent him parameters for both machines. Hopefully it work out.
  11. #31
    Apr 2004
    61
    Hello,
    I am servicing a Amada Pega 345 with Amadan 04PC and The machine is not getting the signal for the TDC, I checked the sensor and it is working, even the signal is in the card, I am looking for documents where i can see how the signal goes from one card to another to see if the wire is broke
    Jorge B.
    jorbercnc.com
  12. #32
    Mar 2009
    101
    Quote Originally Posted by jorber View Post
    Hello,
    I sent reply, I dont see it posted.
    1. Check wires P2-N2 should be 24VDC
    2. Check diagnostic 2008.4, is it 0 at TDC? Put steel in front of switch on / off will diagnostic 2008.4 change? Jog ram off TDC to get cam out of your way for testing
    3. King Or Queen machine? Queen has hyd clutch
    4. Open door with main breaker. Large board inside at top of board should have number TCU1, is it A,B,C? Different schematic for each.
  13. #33
    Apr 2004
    61
    Quote Originally Posted by AMADAJOE View Post
    Hello.
    1. The 24v is Ok
    2. The diagnostic 2008.4 is not changing even in the sensor the LED I can see lightning when put the metal in front. Also I see the leds in the board as in the picture.
    3. Is Queen
    4. Now I am away to see that but let you know later
    Jorge B.
    jorbercnc.com
  14. #34
    Apr 2004
    61
    The Board is TCU1C-00A
    Jorge B.
    jorbercnc.com
  15. #35
    Mar 2009
    101
    [QUOTE=jorber;2218266]The Board is TCU1C-00A
    TCU signal Wire #156 comes into TCU1 board on TM1 Pin 6.
    signal comes out TCU1 M18 Pin 17.
    See if you have signal change in and out of TCU1.
  16. #36
    Apr 2004
    61
    [QUOTE=AMADAJOE;2219020]
    Hello,
    The problem is in the output of the TCU1 without a metal on the sensor is 22V with metal is 24V.
    Who is handling that output?
    Jorge B.
    jorbercnc.com
  17. #37
    Mar 2009
    101
  18. #38
    Apr 2004
    61
    Where is located OPT1?
    I couldn’t find it
    Jorge B.
    jorbercnc.com
  19. #39
    Mar 2009
    101
  20. #40
    Apr 2004
    61
    Ok, then could be PHT4 or PHT1 right?
    Jorge B.
    jorbercnc.com
Page 2 of 3 123
  1. Pega 344 Amada Fanuc 6M electrical diagram
    By nguyenthanhthi in forum Fanuc
    Last Post: 02-07-2024, 10:12 AM
  2. Replies: 5
    Last Post: 12-22-2019, 03:46 PM
  3. Replies: 2
    Last Post: 09-29-2015, 04:02 PM
  4. Replies: 10
    Last Post: 08-10-2011, 10:14 PM
  5. Amada w/Fanuc 04PC ocsillation at stop
    By Mister NCT in forum Fanuc
    Last Post: 06-10-2011, 04:04 PM
