587,125 active members*
2,799 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Chatter when milling in X direction
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Mar 2013
    131
    Re: Chatter when milling in X direction
    I gave up trying to rough or do anything with anything bigger than a 3/8 endmill. I was using a half inch but that extra distance the cutting edges are from the center require more leverage to cut and make these smaller CNC mills chatter. I switched to a 3/8 Kyocera endmill and was able to speed up more than 50 percent. Torque diminishes quite fast the farther you are from center of the rotation and it takes a lot more power to cut. For steel, I use a 3/8 mill with 1/2 inch long flutes when making cuts like what you are doing, it makes a HUGE difference.
  2. #22
    May 2009
    327
    One thing that helped me with some chattering issues was to retram the mill. Helped a ton..
  3. #23
    Aug 2007
    359
    Did you also tram the "nod", if you had any? If so, how?
    Don't have to be too bright to be me
  4. #24
    May 2009
    327
    I did not. My tram was pretty off though.
  5. #25
    Aug 2007
    359
    Thanks.
    I was watching another vid I did awhile back.....I noticed that I got the chatter even on really short cuts in +X direction. I thought it was a work holding problem at the time, but maybe not.
  6. #26
    Jun 2010
    4256
    If it is mainly in the X axis and not in the Y axis, then it is not in the cutter and I don't think it is in the tram either.
    You have something a shade loose on either the X axis or on the milling head in that direction.
    Cheers
    Roger
  7. #27
    Aug 2007
    359
    Yep...just the X. I've heard a couple of Tormach owners say they have similar chatter. It was also mentioned that it might possibly be in the linear ways on the Z axis.
Page 2 of 2 12
  1. Chatter milling in X direction only
    By Mantas in forum Tormach Personal CNC Mill
    Last Post: 04-30-2022, 09:20 PM
  2. Haas VF3 Tool Chatter Issue in X- Direction
    By aaronn in forum Haas Mills
    Last Post: 09-22-2015, 08:59 PM
  3. problem - milling direction
    By spaltiel in forum CamBam
    Last Post: 06-28-2010, 12:13 AM
  4. New Member looking for milling direction
    By Bondomatic in forum Canadian Club House
    Last Post: 10-06-2008, 01:52 PM
  5. v22 CAM: Control direction of milling path
    By tikka308 in forum BobCad-Cam
    Last Post: 03-09-2008, 03:49 PM
