588,182 active members*
4,293 visitors online*
    Nov 2016
    3
    Fanuc 6M major crash
    Hi
    I have a 6M and it started behaving badly - the MDI screen started to flicker and then to go to garbage.
    The problem appears digital (not the CRT)
    Power supply is OK - 5V is stable (added some extra caps just in case) 24V, +-15 also OK.
    Replaced the A16B-1200-0310 monitor board - no change
    Replaced the main board A16B-1000-0030 - also no change
    The system does not have a character generator board A20B-0008-0430 but does have a PC model B A20B-0008-0440 board - does this perform the same task - this has no cable attached but presumably sends the CRT pattern over the address/data lines ??
    The service manual I have is not quite the one for the machine - the CRT interface should either be a A16B-1200-0170 or the A20B-0008-0430
    Oct 2014
    137
    Re: Fanuc 6M major crash
    If in your system is used A16B-1200-0310 that probable reason in PCBs of the monitor. This device have its processor and character generator for processing the video.
    Apr 2009
    1383
    The PC-B board has nothing to do with video.
    Nov 2016
    3
    Re: Fanuc 6M major crash - RESOLVED
    RESOLVED:
    it was a separate PSU in the MDI cabinet that was faulty.
    Quote Originally Posted by pool411 View Post
    Hi
  1. BPT R2G4 Fanuc 11MA Crash
    By leeputman in forum Bridgeport / Hardinge Mills
    Last Post: 02-11-2015, 08:50 AM
  2. fanuc ot- m code crash
    By Jdmmk3 in forum Fanuc
    Last Post: 02-18-2013, 11:20 PM
  3. Fanuc 0i-mc tool crash
    By motordude in forum Fanuc
    Last Post: 05-14-2011, 11:54 AM
  4. What Major incorperates CNC
    By clint_so in forum Employment Opportunity
    Last Post: 06-25-2007, 02:02 PM
  5. major pain
    By JPann in forum Mastercam
    Last Post: 06-05-2004, 03:14 AM
