603,800 active members*
3,733 visitors online*
    Jan 2004
    94
    Fanuc 0i-mc tool crash
    Hello all,
    I was setting the tool length and before doing so I wrote this line (as usual): G30G91Z0.
    Normally the machine returns to zero, but not this time, it went in opposite direction into the table.
    How is this possible? What did I do wrong?
    Best regards
    John
    Feb 2009
    6028
    Seen it before, but with a G28 (first zero return). Every time the G91 was omitted. I know there are a few on here that says you don't need the G91, but all the Fanucs i've set up need it. We had an apps guy do that once, brand new machine, never even cut a part. Bounced the Horizontal spindle off the pallet. 50K damage to the machine. Full rapid 2400 IPM.
    Sep 2009
    84
    If im doing a refrence return though code ive always used G0G49Z0.
    However on an OI-MC you shouldnt have to clear the current height offset to set a new TLO, just jogg the tool to place, then on your desired tool offset punch Z, then hit the input C soft key
  1. After crash zero return doesn't go to tool 1.
    By AvtekMfg in forum Haas Mills
    Last Post: 08-17-2010, 05:52 AM
  2. Tool crash after reconfig
    By deanbayley in forum Mach Software (ArtSoft software)
    Last Post: 08-29-2009, 11:13 AM
  3. Tool Crash During Simulation Problem
    By Cartierusm in forum Dolphin CAD/CAM
    Last Post: 05-29-2009, 08:09 PM
  4. TOOL CHANGE PROBLEM AFTER CRASH
    By roadking in forum Fanuc
    Last Post: 03-24-2009, 02:55 AM
  5. Tool changer crash
    By Vern Smith in forum Haas Mills
    Last Post: 05-05-2008, 11:36 PM
