588,268 active members*
9,754 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Homann Designs TM20LV (BF20,G0704) conversion
Page 13 of 16 31112131415
Results 241 to 260 of 303
  1. #241
    Feb 2013
    164
    Re: Homann Designs TM20LV (BF20,G0704) conversion
    It's worth a shot, but the replacement nuts might not fit. I bought a second nut to double nut one of the screws I already had and it was nowhere close to fitting. I had to go from .125 to .118 balls to get it to fit and it's still tighter than normal.
    Sent from my SM-G920V using Tapatalk
  2. #242
    Aug 2005
    1108
    Yes, that's what I thought. It may be better to buy the screws and ball as a matched set.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
  3. #243
    Aug 2005
    1108
    I have a number of Jigs that I have made for use on my Taig CNC Mill. Now that I have my TM20VL mill operational (Not finished with the conversion yet), I wanted to use one of the jigs on it. The jigs have been designed to mount to the Taig with 10-24 bolts and Taig T-nuts. I need to make some T-Nuts for the TM20VL but with a 10-24 thread, rather than the usual M8 thread.
    The slots in the mill need a T-Nut that is about 12mm high, 16mm wide at the bottom and 10mm wide at the top. The local bolt store that by now, I deserve to go to their Christmas party has some key steel with the dimensions 12" x 1/2" (12.5mm) by 5/8"(15.875mm). This is near enough for the nuts.
    Using the key Steel stock, the machining required to create the T-Nuts is ;
    1. Mill 3mm from either side of the stock to a depth of 6mm.
    2. Score the lengths of the nuts where they will need to be cut with a hacksaw.
    3. Drill with a 4mm bit.
    4. Countersink the holes (forgot to do this step).
    5. Tap the holes to 10-24.
    6. Cut to length.
    7. Mill the T-Nut lengths to size.
    The full story on how I produced them can be seen here;
    http://www.homanndesigns.com/info/in...vl-mill-t-nuts
    A few pics along the way.
    Attachment 314396 Attachment 314398 Attachment 314400
    Attachment 314402 Attachment 314404
    Cheers,
    Peter
  4. #244
    Jan 2008
    1543
    Peter, I see a bandsaw in your future...
    I just got my TM20LV wired up and moving again after a year or so out of action. I think I have the same amount of radial play in my ballscrews that you do (but haven't put an indicator on the table to actually check the movement). Need to confirm how much backlash it translates into.
  5. #245
    Aug 2005
    1108
  6. #246
    Aug 2005
    1108
  7. #247
    Aug 2005
    1108
  8. #248
    Aug 2005
    1108
  9. #249
    Apr 2015
    48
    Quote Originally Posted by phomann View Post
    Hi Peter, what are you making here is it a power supply or new control board. Cheer
    Peter
  10. #250
    Aug 2005
    1108
    Hi Peter,
    It's neither.
  11. #251
    Apr 2015
    48
    Hi Peter,
    It's neither.
    Hey Peter
    Ahh mystery like it watching . Have a great chrissy mate to you and your family. Been making gifts on my CNC thanks Peter
  12. #252
    Aug 2005
    1108
  13. #253
    Aug 2005
    1108
  14. #254
    Aug 2005
    1108
  15. #255
    Aug 2005
    1108
  16. #256
    Aug 2005
    1108
  17. #257
    May 2013
    10
    Sure looks like a power supply mounting board to me.
  18. #258
    Aug 2005
    1108
    It's a chassis plate for the G540 based controller for my mill. There's a bit more to go though. I'll post more after the break.
    Cheers,
    Peter
  19. #259
    Aug 2005
    1108
  20. #260
    Aug 2005
    1108
    The controller box with the components installed. When running off the Ethernet Smoothstepper I use a jumper plug to connect Port 1 of the ESS to the G540.
    Port 2 of the ESS is accessible, whereas Port 3 of the ESS is used internally for the extra axes (Dummied up at the moment). The controller has a number of custom PC boards. The main one, the GC-06 board provides;
    1. 2A 12V power supply for relays and external I/O such as proximity switches, indicators etc.
    2. An isolated 12V Supply for the VFD circuity, allowing the G540 to develop a full 10V control voltage.
    3. Temperature controlled cooling fan.
    4. LED indicators on all inputs and outputs.
    5. Ribbon cable connector for front panel indicators.
    The Aim was to put together a controller that was more than just a G540 and a power supply in a box. I also wanted be able to put a controller together without soldering, and minimizing the amount of wiring required.
    Cheers,
    Peter
  1. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
